i cant find it anywhere the size of the inside gauge suurond
Postby rushing » Fri 16.02.2007, 10:07
hi
:oops: not in manual i think and im going nuts coz i cant find the measurements
can someone please tell me the exact size of the measurements of the Gaeges ring in mm please these are the three gaeges you find on the dash . This is the inside measurement of the ring from one end to the next.
thanks
rushing
Postby RayD » Fri 16.02.2007, 10:43
The outside diameter of the gauge ring on a 1992 SE Turbo is 55mm, and the inside diameter 45mm. Hope this helps.
52 mm
Postby rushing » Fri 16.02.2007, 17:33
are these 52 mm Gaeges as i broke the glass , dont ask how. but need a glass from anothe gaege.
are these 52 mm gauges.
thanks
rushing
Postby RayD » Sat 17.02.2007, 21:05
If some gauges are referred to as ‘52mm’ then these will almost certainly be the same. I imagine the hole in the dash will be about 52mm. The outside diameter of the gauge will be around 51mm and the glass 50 to 52mm. They started life being referred to as 2 inch gauges.
