rip wrote:Yes, they are adjustable.
You can see the rear adjusters. In Sandra's second pic, it is the little blue knob at the end of the thread. When you pull your boot (trunk) carpet back, you get easy access to this.
I believe Nitron modified their front adjusters after fitting mine. Mine are easy enough to get to with a bent wire though. I just remove the centre blanking grommet on the top of the suspension strut & stick my adjuster in the horizontal adjustment slot then turn it.
Both front & rears give a nice positive click for each adjustment increment.
Ah, I was thinking it would be on the top there but wanted to be sure.
Are all the dampers 24 click adjustments? Is the selectable range underdamped to critically damped or is it possible to have an overdamped system with this setup?
Keeping in mind the damping ratio is a function of mass, spring constant, and dampening coefficient we would see the system as overdamped more easily in lighter cars with softer springs
Which brings me to my next question, what spring constants is Nitron offering for the kit? I'd call up Nitron but they're on holiday until Jan-2....
