by Dom » Sun 22.10.2017, 17:00
Evening, All.
SW Lotus have Fed front shocks and springs at a good price, so I’ve bought a pair. According to my research, fitting these may raise the height at the front of the car. SWL, themselves, say as much (c.5mm), but are also confident it’s fine to fit them.
My questions are to do with how the ride height is achieved. Are the shocks longer? Are the springs longer? Can I get the correct setup by taking off the Fed springs and fitting my SE ones to the Fed shocks?
Many thanks for your thoughts,
Dom
Dom
by John_W » Sun 22.10.2017, 21:25
I've been running federal shocks with my original SE springs for the last 9 years/30,000 miles, front and rear. They work fine. Much better than the old worn SE shocks that had done 60,000 miles, and cured the diving under braking and improved the general stability.
I've never measured the springs or the shocks, either before or after fitting them, but I seem to remember that the Fed springs were a bit longer, and were a higher spring rate to deal with the heavier front end, air con etc.. I still have the old SE shocks and unused Fed springs in the garage, so I suppose I could dig them out and measure things if you have the federal shocks to compare.
I'm happy with using new Fed shocks with the old SE springs (assuming the old springs aren't nackered).
- Heid-bummer
by Dom » Sun 22.10.2017, 21:42
John, that’s very helpful and, I must admit, music to my ears. If my SE springs are still good, it sounds like I should be fine. I’ll measure the Fed shocks and let you know.
Where did you get rear shocks from? It might make sense to do the lot while I’m at it!
Thanks again,
Dom.
Dom
by John_W » Sun 22.10.2017, 21:47
SWLotus used to sell sets of federal shocks & springs at Donington in the days of the large Elan meets. I bought a full front & rear set for about £140 and kept them until needed.
- Heid-bummer
by Dom » Sun 22.10.2017, 21:58
I don’t think SW Lotus sell the rear Feds anymore. I might ring them tomorrow to see what they’ve got. I did find a company while searching around this forum that will make up the springs and, apparently, have the necessary information on file to do this:
http://www.coilsprings.co.ukThis could be useful if the springs are past it.
Dom
by clemo » Wed 25.10.2017, 08:04
Sj sports car have standard spring . I bought some a few months back .
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by Sleeka » Thu 26.10.2017, 05:18
Is SW Lotus mean south west lotus or Steve Williams Lotus as those are both options on my google search?
I'm guessing south west lotus as they have parts on the website but their email gets rejected when I try to send them a request. I used their online message form but haven't heard back. Can anyone confirm they are still in business? I need a set of shocks for the front of my fed Elan and they are hard to find.
Sleeka
by Saltire » Thu 26.10.2017, 07:26
Check out the SW Lotus Facebook page - I believe they’ve been having problems with email (and of course a web contact form just generates an email to a predefined address). I believe James also posts on here occasionally.
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by Dom » Thu 26.10.2017, 12:00
Sleeka wrote:Is SW Lotus mean south west lotus or Steve Williams Lotus as those are both options on my google search?
I got the Fed shocks from South West Lotus. They still had a fair few in stock.
Dom
by Dom » Thu 24.05.2018, 18:03
Just to resurrect an old thread, the fed shocks and new SE springs are now on. The car doesn’t look like a boat and is more stable, both when braking and during general driving.
Dom
by Giniw » Thu 24.05.2018, 18:16
Did you source FED rear shocks?
Giniw
by Brit-Car-Nut » Thu 24.05.2018, 19:34
They are basically unobtanium. They went obsolete almost 10 years ago and Lotus didn't have a great amount of stock on hand, so they sold off quickly.
Do you need shocks or springs or both?
by Giniw » Thu 24.05.2018, 19:46
Apparently my rear set is rather asymmetrical so I will need to change the rear shocks one day. Not too much in a hurry, but that will need to be done.
And I can't imagine to change the rear axle only as the front is most probably the same age.
The springs may be all right, they are not rusty at all. That said when I measured the ride height a few years ago it was suspiciously low compared to the workshop manual figure, so either I misinterpreted it, or there is an error, or the car is actually really low. Which seems a bit unlikely when I compare to the official photos of the car when it was new. For now I am not sure of anything, just that the rear shocks were asymmetrical according to the MOT guy one year and a half ago.
Too bad Lotus hasn't conducted a second generation of springs and shocks like they did for the Esprit ... They could at least have a few of them remade to the same specs!
Giniw
by Brit-Car-Nut » Thu 24.05.2018, 19:58
What do you mean by asymmetrical? A lot of shocks have valving designed to best handle the full "roll" of the body in real time.
Front assemblies are available (were last time I checked and still in their catalogue) from South West Lotus Centre.
by Giniw » Thu 24.05.2018, 20:00
I mean that the right one doens't react the same way as the left one according to the MOT guy. So that means one is shot. Or both
Yes I know the front axle is available but I would prefer to get the same at each corner, so ...
Giniw
by Brit-Car-Nut » Thu 24.05.2018, 21:10
Sorry, I can't offer any suggestions. My concern is the FED shocks have the spring mounts in different locations than the RHS and ROW models, so getting FED shocks and using non-FED springs might not be the correct solution either.
The FED car is heavier at the front due to the "crash structure" and a different bumper. I don't remember the rear bumper for my RHS project being as heavy as the FED bumper either, so spring rates should be verified.
The FED car is also a bit higher from the ground than the other models to meet Federal requirements for headlamp position and height.
I remember MG/Triumph had to provide front spring shims to increase the headlamp height on US cars around 1973.
by Dom » Thu 24.05.2018, 21:37
I haven’t tried to get Lotus rear shocks and springs for an SE, but I suspect they’re like hens’ teeth. It would be nice to do all four corners!
Dom
by stevieg8571 » Tue 30.10.2018, 14:05
Hi, I'm very tempted to fit the FED spring/damper assembly as supplied by SWLotus and would like to know if anyone knows the results?
I'd happily accept a 5mm height increase and slightly stiffer suspension for the ease of simply changing the complete unit in one go. Does the camber have to be adjusted due to height increase?
Thanks, Steve
stevieg8571
by Saltire » Tue 30.10.2018, 14:15
FWIW, as part of my current overhaul, I’ve replaced the old springs and dampers on my UK car with OEM springs (SJs) and Avo dampers (Merlin Motorsport). Didn’t find it a particular problem to change them like that; springs and dampers were separate anyway and assembly was just a matter of mounting spring to damper and checking the ride height.
by Steve_P » Tue 30.10.2018, 14:45
If the springs are original they will almost certainly have sagged significantly over time. I managed to get a complete set of new S2 springs and dampers from Lotus about 10 years ago and can remember thinking the car
looked like it was on stilts after fitting them
but the ride height front and rear was correct and the car felt a lot better. So, if you have new springs it might be worth fitting them in my view - Steve PS just seen this an
old thread and you're all good!
Steve_P
