Rear Wishbone/Anti Roll Bar Help Required
Re: Rear Wishbone/Anti Roll Bar Help Required
Postby nicowalker1 » Thu 20.06.2013, 17:22
I am no mechanic but managed the rear wishbones. It is just time consuming getting the old ones off.
I had two axle stands under the rear bar that the wishbones connect to, its tight but it worked...
Also, I fit S2 bones to my SE, I didn't come across any fitment issues at all, was a straight swap :-D
nicowalker1
Postby Rose Royce » Sat 22.06.2013, 03:24
tweetdriver63 wrote:Is there still a source for the stainless wishbones? I'd like to get some since I have some rust to deal with on mine and I now have the financial resources to replace them.
I don't want to disappoint you, but I believe I got the last set.
Rose Royce
Postby ccb056 » Tue 23.07.2013, 08:05
I am in talks with a local guy who specializes in fabricating suspension parts.
I am currently getting group buy quotes for rear axle spindles, stainless rear wishbones, and rear anti-roll bar ball joints.
ccb056
