bobbrown wrote:I feel a lot of you are missing the point, the amount of braking that can be achieved on the front is no different on the standard brakes as it is on an upgrade it just takes more effort (pedal input) to achieve.
The amount of weight transfered during braking is down to the tyres you have fitted not the brakes.
It is the tyres that stop the car!!!!!!!!!!!!!!!!!!!!!!
With out the back brakes operating correctly then the cars stopping distance will go up, this is a fact not just a theory more so in the wet.
On a dry road you will get more weight transfer than on a wet road due to the extra grip from the tyres, note the tyres not the brakes.
The car would have been engineered to give good brake ballance in wet and dry conditions so this is always a compromise.
That is also why race and rally cars have adjustable brake bias to "dial in" the brakes for track/ stage conditions.
RayD wrote:I understand what you’re saying Bob,
I was using it to bolster your point that it’s the tyres that stop the car.
I’d used up the “all other things being equal” phrase in another sentence.
Generally speaking, and all other thing being equal, a narrow tyre will lock up sooner than a wide tyre.
a5gcd wrote:Those of you who bought from Rally Design when I arranged the group discount will all have 120-6816s as I have.
I have spoken to Lee at Rally Design and explained the "mistake" and they have offered us the same deal as before. 120-6806 calipers for £69.50 instead of the normal price of £89.50 + VAT of course. Give him a call, quoting Lotus Elan group buy, if you intend to take up his offer.
01795 531871
Wilwood's web site has a single spec sheet for all Forged Billet Dynalite Calipers. That specsheet lists 7112 pads as appropriate to all. I therefore believe the answer is "yes".Paul.P wrote:Does anyone know if the 6806 calipers use the same pads as the 6816 ?
paulrwebster wrote:As Geoff has already ordered his, it might be a good idea to hold off a little while and get his feedback on the performance of the replacement calliper.
Got this from a site discussing BMC needs when converting from single-piston-calipers to 4-piston-calipers:JIMBO wrote:I dont think just replacing the MC with a "like for like" item will assist this. Surely this pedal travel is down to the size of the pistons now being moved and a greater amont of fluid moving more quickly. Perhaps a Cylinder with a greater capacity might help?Monty wrote:Jim,JIMBO wrote:Great stopping power, but longer pedal travel.
I can feel another mod coming round the corner.![]()
Ever since i did my wilwood up grade Pinky has a longer/soft pedal travel, i've ordered a new master cylinder from the USA to see if that'll make a difference
Bore Size Disc Width Blk Part# Polish Part#
1.75" 44.5mm .81" 20.6 120-6816
1.62" 41.1mm .81" 20.6 120-6811 120-6796-P
1.38" 35.1mm .81" 20.6 120-6806 120-6791-P
See chart. Pad contact area per caliper for the Powerlite (aka 15" kit) is 22.8 SqIn VS 29.9 SqIn for the Dynalite (aka 16" kit), translating to a front-brake swept-area of 45.6 VS 59.8 SqIn. In addition (referring to the chart below) the smaller-piston size of the 15" kit only offers 62.5% the clamping-force of the 16" kit. Can those with the smaller 15" Wilwood kit still lock their wheels?
I'm in favor of the 6806, but I thought others might find some of these caliper facts relevent. Hey, I had already done the research!Doug wrote:wow, the great caliper discussion thread continues
where's ESM with his scientific graphical analysis -- (probably keeping quiet on purpose)
Matt's attic holds a painting of an Elan slowly metamorphosing into a rusty, crumbling Lada.algirdas wrote:Matt-How do you keep that undercarriage so clean? After seeing yours, I look at mine and just want to hurl.
algirdas wrote:Dear All:
A pair of 6806s should be delivered to my house tomorrow afternoon. I'll try to get them on this weekend and do some comparison testing (assuming I get the system bled properly) while sensations are fresh in my mind (and right foot).
Matt-I held off ordering a set for you since you appear to be vacillating on making the switch. If everything falls into place, you should be able to order directly from Wilwood and get the discount pricing. I'll keep you posted.
Sincerely,
Algirdas
tigerdog wrote:Matt's attic holds a painting of an Elan slowly metamorphosing into a rusty, crumbling Lada.algirdas wrote:Matt-How do you keep that undercarriage so clean? After seeing yours, I look at mine and just want to hurl.
ailwyn wrote:tigerdog wrote:Matt's attic holds a painting of an Elan slowly metamorphosing into a rusty, crumbling Lada.algirdas wrote:Matt-How do you keep that undercarriage so clean? After seeing yours, I look at mine and just want to hurl.
Not another Grey member?
nitroman wrote: ... the smaller-piston size of the 15" kit only offers 62.5% the clamping-force of the 16" kit. Can those with the smaller 15" Wilwood kit still lock their wheels?
... I may have talked myself out of this. Whilst initial application of the pedal would yield a quick response, the reduced clamping-force (and therefore stopping-ability) could be extremely dissapointing.
