by Jeemy » Thu 23.05.2013, 19:42
• IE.4 - PARKING BRAKE MECHANISM
It is important, if the self adjusting mechanism is to function correctly,
that UlC caliper levers are fully back against their stop brackets when the
parking brake is 'off'.
To Adjust:
I. Ensure that the pads are at their working position, by applying hard pressure
to the footbrake pedal several times.
2. At each caliper, check that the parking brake lever is fully against its
'off' stop bracket, and check that when the parking brake is applied and
released, the caliper levers return immediately, and are not delayed by
excess friction in the cables or linkage. Rectify as necessary.
Page 1
Cable abutment
bracket
Lever return
Caliper parking
brake lever
Lever in contact
with 'off' stop
PUll out the tunnel top oddments tray to gain access to the parking brake
cable adjusters at their forward end abutment. Use the adjusters to remove
the slack from each cable, but ensure that the caliper levers are still in
contact with their stops.
4. Operate the parking brake several limes to allow the automatic adjusters
within the caliper to take up any excess clearance, and check that the
parking brake lever travels no more than 7 clicks when fully applied.
S. Refit the tunnel top tray.
T: 0800 084 3084
M: 07391 295 146
