Although my car passed it's MOT today after failing on Thursday, the various brake forces of the pass/fail results seem most odd.
I stripped down one proportioning valve(rear UK driver's side), cleaning it and then replacing/bleeding that corner. I didn't touch any other caliper/valve/MC at all.
But the fail and pass brake test results are baffling to say the least (it failed on the rear axle balance L to R):
Fail results:
Front L 283 HB L 155 Rear L 148
Front R 389 HB R 156 Rear R 101
Pass results
Front L 313 HB L 113 Rear L 75
Front R 303 HB R 156 Rear R 98
The really strange one is the hand brake. I didn't change or adjust it in any way, so how come the reading drops from 155 to 113? Similarly the front brakes were untouched.
Could it be that the pads weren't warm enough? Could the fluid be off and need totally replacing? Or is there some other aspect I have overlooked?
Edited to correct brake corner labels. Thanks Simon see below.
