by dapinky » Wed 11.09.2024, 14:11
Joao,
There are various things to keep in mind with these things - the foremost (to me!) is that the item has to be capable of performing it's job 100% of the time, for a 'reasonable' timespan....
.... I would expect any brake hose to have an expected lifespan of 30+ years (as many Elans are still on the originals, but my VW needed 2 new ones at 12 years, and I have the originals on the Landrover at 20 years).
Having replaced many over the years, I am aware that it is often a bit of a struggle to undo the joint between the flexible hose and the hard pipes - so I get Stainless Steel fittings wherever I can - many brake hoses use plated mild steel. Now, this is (as always) a bit of a technical compromise, as plated mild steel will cope with higher pressures before failure than Stainless - so it is also down to the actual 'bulk' of the fitting as much as the material.
Obviously, the hose itself also has to be of a suitable quality......
..... and I tend to rely on people using/supplying stuff which has been tested to the appropriate CE/TUV standards.
For example, it is possible to buy a length of braided hose and the end fittings from Aliexpress, and make up your own hoses - but I wouldn't! For a start. the crimped ferrules need special kit and skill to operate correctly. It is possible to buy compression fittings with brass olives (like plumbing fixings) - but they are not road legal in the UK/EU.
So, we are at the mercy of someone who sources the right kit, and has the skill to provide them - personally, I think £100 for 6 is very reasonable (bearing in mind that when LEC did a group buy 15 years ago it was £71 for a set with stainless fittings (requiring 10 sets, so it didn't happen)..... I did partake of the one a year or so previous to that though, at £65 for a full set. (IIRC).
