dapinky wrote:Front tracking
Rear tracking
Front Camber
Front Caster
Rear Camber
Front tracking (again)
Fredjohn wrote:In theory you don't need to use a Lotus specialist. Just search for Hunter Hawkeye alignment in your area. The machine has a large database of suspension settings for cars, including the M100 Elan.
The slight downside is they probably won't have spare shims to hand. But the ones you have on your car may be suitable if correctly positioned or turned over. Or you can buy from a Lotus dealer once you know sizes or make your own.
The machine can also do rear alignment.
Simon_P wrote:You can get the tracking close enough with a roll. of string and a tape measure .
The camber can be done with a piece of aluminium angle, 2 bolts and four nuts and a bubble level app on your phone.
See YouTube for how.
Tuga2112 wrote:if we are getting pedantic here. you also need balast in the driver's seat to a similar weight to the driver...
