by Lotusian » Tue 08.09.2026, 14:36
I have height-adjustable dampers on my SE and would like to correctly set the ride height. I find it difficult to crawl around under the car to check ground clearance as specified in the factory data (with 1/2 tank of fuel plus 75kg driver), so could some kind person please make life easy for me by advising the clearance under the front and rear of the sills. Thanks
Lotusian
by simonbuk » Thu 10.09.2026, 18:02
Hi, havent managed to do this yet as mines not on even ground, might be moving it tomorrow so will be able to do it if you still need it ?
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
- Location: Mostly Worthing,West Sussex, sometimes the canals.......
by Lotusian » Thu 10.09.2026, 18:08
Yes still wanted please
Lotusian
by Dave Eds » Thu 10.09.2026, 20:42
Are you running standard SE wheels?
by simonbuk » Thu 10.09.2026, 22:49
Dave Eds wrote:Are you running standard SE wheels?
Me or him ?! Actually I'm an S2 so don't know if there's a difference ?
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by Lotusian » Fri 11.09.2026, 08:35
Standard SE 15” wheels 205/45 tyres
Lotusian
by simonbuk » Fri 11.09.2026, 10:10
Lotusian wrote:Standard SE 15” wheels 205/45 tyres
Aren't they 205/50 ?
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by Fredjohn » Fri 11.09.2026, 12:52
simonbuk wrote:Lotusian wrote:Standard SE 15” wheels 205/45 tyres
Yes 205/50.
by simonbuk » Mon 14.09.2026, 13:17
Right, on an S2 (bigger wheel but smaller profile).
Front 18.7mm
Rear 19.3mm
Measured under the furthest part of the sill front or back (nearest the tyre), where the curved part of the bodywork goes under and becomes level. If that makes any sense !!
simonbuk on Tue 15.09.2026, 10:30, edited 1 time in total.
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by Lotusian » Tue 15.09.2026, 00:20
Thanks for this
Lotusian
