by jello » Mon 21.05.2007, 04:02
The upgrade page is very nice with the article on upgrading to stainless wishbones from Surrey Welding (for the rear suspension). I'd like to do this upgrade, but the weblink is down.
Does anyone know if Surrey Welding is still in business, and how to contact them????
Phil Bates
jello
by Sy V » Mon 21.05.2007, 10:43
Still in business? = I fear not (or, they might be in business but not doing the WBs anymore...)
- LEC Godfather
by Candles » Sun 27.05.2007, 09:44
Phil,
I leapt on these wishbones about 5 or 6 years ago. They were then, and still are fantastic. The problem was that they were flogging them for about £330 IIRC, which, considering the work that had gone into them, made them uneconomical to produce and they stopped. Bummer huh? I wanted front ones as well!
Candles.
Candles
by lotuselan4455 » Tue 29.05.2007, 18:35
If I can get hold of a second hand set of rear wish bones or better still drawings, I've a Tool Room Company who can make these, possibly beat the price also..
lotuselan4455
by Doug » Tue 29.05.2007, 19:18
go for it and tell us what the projected cost will be -- then gauge interest and see if it is worth making them
they certainly are an item that is needed for the model
- LEC Founder
by Candles » Wed 30.05.2007, 10:46
People seem to be getting the South West Lotus galvanised rear 'bones for about £230 IIRC so that'd be hard to beat. How about going for front ones?
Candles.
Candles
by SteveB » Sun 03.06.2007, 22:36
SW still don't have a supply for these wishbones as there supplier went belly up. I need a pair and am on the waiting list if they sort out the prob.
SteveB
- Tinkerer
by Candles » Mon 04.06.2007, 09:33
Well maybe there is a niche then! I'll sign up for front ones!
Candles
by JohnSlovenia » Sat 12.03.2011, 20:06
Anything moved on this in last 4 years? I'm sure its worth someones time at say £300ish? must be worthwhile?
JohnSlovenia
by HJ2 » Sat 12.03.2011, 20:51
by theelanman » Sat 12.03.2011, 22:27
JohnSlovenia wrote:I'm sure its worth someones time at say £300ish?
that'll just about cover the cost of the bushes.....
by JohnSlovenia » Mon 14.03.2011, 17:28
So you are saying that with the tinbits the wishbones would be what? £600 a side???
JohnSlovenia
by Brit-Car-Nut » Mon 14.03.2011, 21:52
EACH Rear lower wishbone needs:
Qty: 2 - E100C6002F Inner Bush (everyone is using B100D6002F)
Qty: 2 (or 4 if none of the above) - B100D6019F Inner Bush @ 10.03 each
Qty: 2 D100D6002F Outer Bush @ $30.01
Prices are from SJ price list, last month
TWO Wishbones would be 200.28 plus postage PLUS Installation Labour
by theelanman » Tue 15.03.2011, 00:14
Brit-Car-Nut wrote:EACH Rear lower wishbone needs:
and VAT at 20% if youre in the UK
I had them made.....but needed to order them in bulk to get the discount.....
jimbob got the original spec lotus rubber type and IIRC they came in at about £240 for the complete rear end...
the bulk order got the poly bushes in for £150 for enough to do the rear end.....
by JohnSlovenia » Tue 15.03.2011, 19:04
So guys please simplify.
What will I have to pay for a pair of wishbones, complete with bushes and anything necessary, including UK VAT --and
where can I get them?
Sources I have seen mentioned seem to have dried up.
JohnSlovenia
by Brit-Car-Nut » Tue 15.03.2011, 19:19
If you are looking for a set of stainless, then look here:
Stainless Wishbones incl bushesIf you are looking for regular Steel, Try SJ Sportscars. They have the links with bushes for 396.55gbp each side.
SJ Sportscars LimitedIn my price book, they are on page 32, under links and wishbones.
I believe they are the newer S2 design but they will fit all models.
by Brit-Car-Nut » Tue 15.03.2011, 19:24
Send Dave Eds a PM. He will get a notice that you did.
