Rear brace: Right side detail
Rear brace detail 1:
Rear brace detail 2:
Rear brace detail 3:
kmckmc wrote:Front brace: What it would look like.
algirdas wrote:I have agreed to do what?
I better find out if they make a "long" lens for my camera.
Algirdas (a crotchety old fart in his own right)
RayD wrote:Thanks Geoff,
I hadn’t read the Dave M’s Strut thread until now. My post was only in answer to the question raised by kmckmc.
If the standard chassis is too solid to be improved by a strut, then the reason for the rear wheel lifting sooner when using the front jacking point would be down to the improved fixture between the body and the chassis after a strut bar has been fitted. In other words you could get the same result by just fitting a top flange and increasing the number of fixing bolts.
Ray
Doug wrote:Perhaps you could consider the bar as a rear tow bar for when Monty is stuck spun around off the track
