racerstev wrote:What is really needed once you start raising boost levels is a wideband O2 sensor.
You need to be able to see what the air/fuel ratio is to keep things safe.
surfboardfiller wrote:From what Tony said, with the safety fuel cut off operating at a relatively low boost pressure it seems I need an Everest chip to solve that and the chip and ECU will still be able to operate successfully in all other tasks than boost control.
If I want to go over 1 Bar boost, I will need injectors that can inject enough fuel into the higher air pressure than normal, to fuel correctly.
surfboardfiller wrote:Will that work at the top of a mountain? or will it only work at 1 bar atmospheric pressure?
surfboardfiller wrote:Can I plug any ECU into my car? I have a few and one had an Everest v4.5 chip in it.
rip wrote:Tigerdog's Elan is.
Monty wrote: my spare dosh is going on my old Tranny
Quote of the decade from the Murphmeister tigerdog wrote:So why do I still have an MBC? Because there isn't an ESM alternative for the 550cc+3 Bar combination yet (t-dog crosses paws/fingers, wishes upon a star.)
surfboardfiller wrote:cross my paws that ESM makes a map that is compatible with the increased injector size and 3 bar map sensor.![]()
ESM wrote:I have a wide band sensor kicking around waiting for me to get the red car sorted. It's a nice piece of kit because it can simulate a narrow band sensor output so it can be used for closed loop control with the standard ECU as well as having the ability to monitor high boost mixture.
surfboardfiller wrote:I guess all you need is a 3Bar map sensor and some bigger injectors for Christmas/Eid/Divali/Hanukkah![]()
I don't know how much they cost though. - Doug?
