Samco silicone coolant hoses, possible group buy.
Postby Monty » Tue 14.03.2006, 20:44
chrisP wrote:Hi All, I have been fitting the hoses this week while the head is off (which makes things much easier) the fit and finish on the hoses is great apart from the one that goes from the electric coolant pump to the left hand radiator hose(looking at the front of the car). Obviously it replaces the metal intermediate pipe but the new hose is not long enough to fit in the metal pipes clip and so it rests on top of the anti-roll bar and also is pinched between the body work and the turbo wastegate valve. Has anyone had the same problem as I'm thinking of cutting the Samco pipe and putting the metal pipe back
Chris, it won`t fit in to the same clip, u need the clips to attach to the rollbar (the same as the S2)
The SE buyers will also need clip for the main radiator hose:-
Swivel clip hose to anti-roll bar A100W6455F £1.31 from SJ's. Better of using 2 to keep the hose in shape.
I`ve had no trouble with the hoses fitting :?
Postby chrisP » Wed 15.03.2006, 13:31
Hey thanks Monty I must have skimmed over that great bit of information. that helps alot, I'll get on the phone to SJ's right away
chrisP
Postby M100 TWO » Wed 15.03.2006, 20:00
it would also pay to put in place two sacrificial rubber pads around the hose, I cut mine out of the old existing top rad hose and used tie wraps to hold in place
john
M100 TWO
Postby TheBard » Wed 15.03.2006, 21:02
Ordered mine, in Red from James today. He said he has black and blue in stock, the red have a 4 week lead time, worth the wait methinks :-D
Not sure on total price yet, but will update with more details later. Also, as mine is a Fed I discussed the slanted radiator, and the extra distance needed to the lower connector, James said they'd see what they could do, so I'll let y'all know what happens.
I'm excited :D
TheBard
Postby chrisP » Thu 16.03.2006, 14:37
Not a bad Idea John, I'll probably do that as well then to be safe, I also replaced the original "hose protectors" (for want of a better word) that were on the hoses around the thermostat housing, you can't be too careful can you
chrisP
Postby Dave M » Tue 11.07.2006, 13:15
As a follow up to the fit of the UK hoses to the US car, I can report no problems or leaks. As noted on the previous page, there were a few modifications to make things fit, but nothing major. This may be a moot point as it appears a group is trying to get together to do a US group buy, but if it doesn't work out or someone wants the replacements sooner, this is a viable alternative.
Note that the 90 degree bend below may not be necessary to adapt the UK -> US. I used it for a better fit between my aftermarket intercooler and aftermarket radiator.
Coolant hoses from:
http://bakerprecision.com/purosil.htm
Barbed connection/splice and hose clamps from:
http://www.mcmaster.com/
Dave M
Postby nitroman » Thu 09.11.2006, 00:17
Yamaha! Are their products factory recommended for Lotus repair... or have you been breathing 2-stroke exhaust again Dave? :wink: I used to own an RZ350 BTW, the black & yellow Kenny Roberts edition. A true bonzai ride and the last of the great 2-stroke sport-bikes ever allowed on American roads. RIP, old read-valve exhaust pollution.
nitroman
Postby Dave M » Thu 09.11.2006, 05:04
Well, the recommendation I read a number of places was Hondabond...but I thought that might be cause for a sacking. :roll:
Dude! The RZ350? Sweet bike...
Dave M
Postby nitroman » Thu 09.11.2006, 08:32
Yes, and everyone bought Canadian-pipes & carbs to take away the hesitation, flat-spots & bogging... which also added 12 to 16 HP. Those were the dark days of even Florida emmisions testing but it took less than an hour once a year to swap those parts!
The RZ was the 1st bike to my knoweldge forced to have cat-converters.... a sure sign the end was nigh!
Man, I fit that bike like a fine babe. It was just ergonomically perfect for my dimensions. Going over a hill and catching air I just hugged my thighs under the bulge in the tank and we remained as one. A true Armanie suit! I sold that bike when Rachel wanted a baby and a father to raise her!
nitroman
Postby kmckmc » Wed 22.11.2006, 03:47
Hi,
I am slightly CONFUSED.
I have a 1995 Elan M100 S2 (Left Hand Drive).
Which water hoses should I buy? THE UK one or FED one?
Please advise.
Cheers,
Elan M100 S2
kmckmc
Postby Doc Fizzix » Wed 22.11.2006, 05:55
kmckmc wrote:Hi,
Please advise.
Cheers,
FED
Doc Fizzix
Postby kmckmc » Sun 04.03.2007, 16:27
Hi,
I have an S2.
So, I ended up getting the UK spec. Samco hose.
However, I forget to buy the 16m-19m stepped connector from Amber Performace. According to the previous post, the price including postage and packing is £14.79 from Amber Performance.
Cheers,
Elan M100 S2
kmckmc
The complete set of Samco hoses
Postby kmckmc » Thu 08.03.2007, 08:42
Hi,
I received the Samco UK spec. hoses for my S2.
This is the picture.
Elan M100 S2
kmckmc
Postby Ekapol » Fri 09.03.2007, 00:49
Ummm... Yummy hoses. :-D
Ekapol
Postby Monty » Fri 09.03.2007, 15:34
Just a warning, after having the Hoses on for quite awhile and whilst i was fitting the AB Short shift i checked the hose clips and they were all lose. Must be the hoses being new and shrink slightly with the heat.
If you`ve got Samcos fitted recheck the hose clips
Postby nissias » Mon 12.03.2007, 16:33
how much is this kit and where can I buy it? :)
nissias
Postby Monty » Mon 12.03.2007, 16:40
read through the bloody thread :roll:
Postby Dico » Mon 12.03.2007, 18:15
It took me a while to find the related thread, but I finally found it, its here -
http://lotuselancentral.com/forum/viewt ... sc&start=0
Postby Ekapol » Mon 12.03.2007, 22:42
Dico wrote:It took me a while to find the related thread, but I finally found it
:smt044
Ekapol
Postby Enright » Tue 13.03.2007, 00:03
:clap:
Return to Upgrades
