Optimal exhaust pipe diameter varies with engine displacement, horsepower and whether the engine is normally aspirated or forced induction. Exhaust velocity is directly related to pipe diameter. A general rule is the smaller the pipe, the higher the velocity. High exhaust gas velocity helps scavenge the cylinder, especially at lower RPM. However a pipe that is too small in diameter will have high exhaust gas velocity but restrict air flow, whereas a pipe that is too large will have a lower exhaust gas velocity but have high air flow. The optimal pipe diameter is a size that facilitates both high exhaust gas velocity as well as high air flow. The follow table is a general guideline for single exhaust systems<br><br>Horsepower Engine Size N/A Forced Induction Pipe Size<br><br>0-100 0-2.0 L x 50mm<br>101-150 0-2.0 L x 50-60mm<br>151-200 1.5 L-2.5 L x 50-60mm<br>151-250 1.5 L-2.5 L x 60-70mm<br>200-300 5.0 L-5.7 L x 80mm<br>251-up 1.8 L-up x 80mm
<br><br>I'm a bit confused about this remark, at constant speed the revs will be determined by which gear you're in and the ratio it gives. The upgrade shouldn't affect the revs (only the rate at which they increase). Boost will be operative only at significant throtte openings.<br><br><br>I drove around for about 20 minutes before giving in to the rain. I noticed that even though I drove at a constant speed the unusually high revs would eventually drop down and settle...<br>
<br><br>The learning of the ECU is often overstated, I believe that the ECU only learns the best starting IAC valve position and in the S2 the typical fuel trim needed to keep the oxygen sensor happy. Neither of these will be influenced by driving style. The learning is continuous anyway, it never becomes writ in stone.<br><br><br>My question relates to the ECU, its need to "relearn" after the battery is disconnected and whether this would affect chip performance?<br><br>How long does it take to fully "relearn", and does driving ability affect what it learns i.e. If driving like Miss Daisy would the ECU adapt to that driving style until an aggressive style of driving was used instead....?<br>
