any one interested in msd coil packs ?
Postby addict » Thu 21.02.2008, 22:06
i have a pal who is a msd uk agent and i have asked him to bring some in for me.
anyone else want a pair ?
if it could be sorted quick i can take them to Donington. :wink:
Primary Resistance: .35 ohms
Secondary Resistance: 7.8K ohms
Maximum Voltage: 40,000 volts
Induction: 4.2 mH
Turns Ratio: 80:1
Installation Tip: If you plan to install an MSD DIS ignition, use Interface Module 121-8870.
£83.50 a pair
addict
Postby GeoffSmith » Thu 21.02.2008, 22:12
Prices?
Postby Monty » Thu 21.02.2008, 23:51
Wouldn`t mind a set
but depends on price as i`m skint at the mo
Postby Specky » Fri 22.02.2008, 06:09
Me too, but price is a factor...
Postby Paul.P » Fri 22.02.2008, 07:45
Addict, let us know how much & if its reasonable then yes !
Postby addict » Fri 22.02.2008, 09:26
Paul.P wrote:Addict, let us know how much & if its reasonable then yes !
when i get the numbers you will be the first to know
i also have other things to look 4 leadsets cas caps ect
also found this not what im thinking of ordering tho
Reengineered to be the only true performance AC/Delco style DIS coil. ''Raised Dome'' construction, section bobbin technology, highly specialized silicone magnetic steel core along with optimized windings, resistance and turns ratio results in higher energy and voltage outputs and longer dwell. Compatible with OE computer controlled ignition system as well as a Crane or MSD capacitive discharge DIS ignition system. High dielectric strength ''Accel Yellow'' over molded housing. Packaged as single unit: 4-cyl require 2 coils, 6-cyl require 3 coils and 8-cyl require 4 coils.
Specifications include: 11% peak increase in energy over OE. 21% peak increase in voltage over OE. 21% peak increase in dwell over OE. 12% peak increase in current over OE.
just searched the net and these dont have a good reputation,
addict
Postby theelanman » Fri 22.02.2008, 09:38
yep, interested :-D
cheers
G
Postby ailwyn » Fri 22.02.2008, 10:55
I'll be in for 4 coils if the price is right.
Could also be interested in the other bits too.
Ailwyn
Postby Nige » Fri 22.02.2008, 20:19
Interested, but like everone else dependant on price, (although the way things are going a group buy discount should be available).
Back in Blighty
Nige
Postby dapinky » Fri 22.02.2008, 20:26
ditto
Postby Dico » Fri 22.02.2008, 21:40
Yes please :-)
Postby al » Sun 24.02.2008, 11:25
yep, depending on price.
al
LEC Bit Basher
Postby addict » Sun 24.02.2008, 11:50
just had word £83.50 a pair :wink:
addict
Postby Specky » Sun 24.02.2008, 13:14
addict wrote:just had word £83.50 a pair :wink:
Soooooo.............
In therory...you remove the old coil pack complete with base plate and fit the new items in...?
Postby al » Sun 24.02.2008, 13:47
Are these the #8224 ?
MSD will ship a pair to the UK for $123 (£62):
http://www.shopatron.com/product/part_number=8224/424.0
course you might end up having to pay a bit for import duty (though they do seem to give the option of marking it as a gift...)
can your mate do a bit better if there's a group buy arranged ?
al
LEC Bit Basher
Postby dapinky » Sun 24.02.2008, 14:04
JEGS
or
SUMMIT
are half the price, but that said, SUMMIT add a $24 overseas shipping 'handling charge' - 1 per order, however big or small, plus both will charge for shipping (cost not quoted on website), and then there is the issue about import duty.....
All in all, there is a lot to be said for the known, fixed price & convenience of picking a pair up at Donny, but not for me at this time, ta.
Of course, with all of our USA friends coming over for the big 60 birthday later this year, I can see a lot of 'excess bagage' being charged for by the airlines - I for one will be happy to pay for some of the extra killos, if anyone's offering :wink:
Postby addict » Sun 24.02.2008, 16:52
i think these fit on the original base
addict
Postby Monty » Sun 24.02.2008, 17:00
You can also get these on ebay
search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=MSD+8224&category0=
Since i`m bloody skint at the mo and at £85.50 which IMHO isn`t a great deal since you can order them direct from the USA for about the same price i will have to drop out.
Cheers for your efforts thou
Postby theelanman » Sun 24.02.2008, 18:53
IIRC the esprit has the same coils and these are available at £70.....
like the guys say we can get em from the US at $90 for a pair (so thats less than £50....even with shipping and IF you get caught at customs I cant see it being more than about £75 total).....
see if he can do any better otherwise I may pull out too...sorry
cheers
G
Postby Specky » Sun 24.02.2008, 19:17
theelanman wrote:IIRC the esprit has the same coils and these are available at £70.....
cheers
G
Lotus are back to £240 odd again... :(
I tried the ither day..
Return to Upgrades
