abmunro wrote:Has nobody enclosed the induction kit.
Then utilised the pipework leading to the Dustbin
petestubbs wrote:A quick question about the one that drops in the bin though, does it give better performance?
Or more to the point does it sound better than the standard filter?
max and andy wrote:Ive been reading the forums,on K.N open filters.The forums seem to suggest that there are problems with them taking in hot air.And that closed filters are now thought to be a better way to go.I was also reading the Upgrades section at the top of the index page.This says that in Summer and when the engine is running hot.The filter and pipe and the area around the filter,felt cold to the touch.Which is now thought to be the best choice ?Open or closed. Max&Andy
rip wrote:Does intake air temperature matter too much with a turbocharged/intercooled engine? All air will be heated when it flows through the turbo or wastegate, then cooled again by the chargecooler.
May be an awkward test to perform. By the time the air filter had been changed, ambirnt temperature would likely to have changed too, which would screw up the results of any such test.
