Blue_Bullet wrote:Look what i found while browsing ebay
http://cgi.ebay.co.uk/MR-2-MR2-SW20-Rev ... 33586b4192
Looks simular fit to the Elan>?
wonder what they would look like? Anyone sh1t hot at Photoshop and can paste them on ?
dapinky wrote:and possibly with the distance between the light source and the brake lamps
Gee0 wrote:FYI It is not a legal requirement for MOT to have a reversing light!!!!!
Blue_Bullet wrote:I think you posted the worng link Tweetdriver lol
Yes Maybe just go for two reverse lights cutlea rather than 1 fog and 1 reverse!
Sticking my oar in?
Gee0 wrote:I fitted my Fog and reversing lights behind the grill in to lower rear bumper, and it has passed 2 MOTs since.
dapinky wrote:Just to clear that bit up, I'll refer you to the Statutory Interpretations
“Angles of visibility”
A requirement for a lamp or reflector fitted to a vehicle to have specified horizontal and vertical angles of visibility is a requirement that at least 50 per cent of the apparent surface must be visible from any point within those angles when every door, tailgate, boot lid, engine cover, cab or other movable part of the vehicle is in the closed position.
"Apparent surface"
For any given direction of observation, is the orthogonal projection of a light-emitting surface in a plane perpendicular to the direction of observation and touching that surface.
“Separation Distance”
In relation to two lamps or two retro reflectors the expression means, except where otherwise specified, the shortest distance between the orthogonal projections in a plane perpendicular to the longitudinal axis of the vehicle of the illuminated areas of the two lamps or the reflecting areas of the two reflectors.
“Illuminated area”
The expression, in relation to a headlamp, front fog lamp and reversing lamp, in each case fitted with a reflector, means the orthogonal projection of the full aperture of the reflector on a plane (touching the surface of the lamp) at right angles to the longitudinal axis of the vehicle to which the lamp is fitted. If the light-emitting surface extends over only part of the full aperture of the reflector, then the projection of only that part shall be taken into account. In the case of a dipped-beam headlamp, the illuminated area is limited by the apparent trace of the cut-off on the lens.
The expression, in relation to any other lamp, means the part of the orthogonal projection of the light-emitting surface on a plane (touching the surface of the lamp) at right angles to the longitudinal axis of the vehicle to which it is fitted, the boundary of which is such that if the straight edge of an opaque screen touches it at any point 98 per cent of the total intensity of the light is shown in the direction parallel to the longitudinal axis of the vehicle. Accordingly, for the purposes of determining the lower, upper and lateral edges of the lamp, only a screen placed with its straight edge horizontally or vertically needs to be considered.
So now we all fully understand exactly what is required - simple really![]()
2 reversing lamps isn't a problem - but you will still need a fog lamp - and the LED's wouldn't meet the regs to be a 'reversing lamp'.
