Whats the thinking of using a Fuel cut defender
The TurboSmart FCD is here http://www.turbodynamics.co.uk/shop/ts0 ... rrency=GBP
Sandra
theelanman wrote:have you got a mountain chip?.....
this will get rid of the need for this.......
m100sandra wrote:Since having the Piper 2.25 and Everast fitted
rip wrote:theelanman wrote:have you got a mountain chip?.....
You a bit sleepy today, G?m100sandra wrote:Since having the Piper 2.25 and Everast fitted
dapinky wrote:Sandra, has your wastegate been ported?
Is it operating 100% correctly with no slight sticking ?
Before spending 100 quid on something which *could* harm the engine, I'd see if the overboost can be prevented. (of course, if the intention is to maximise boost over and above what the Everest gives for more power, then I'll shut up!)
m100sandra wrote:Since having the Piper 2.25 and Everast fitted i hit the fuel cut last night for the 1st timei thought i had got away with it, but maybe with it been a bit cooler last night its just hit it.....
Whats the thinking of using a Fuel cut defenderi was maybe thinking of using a TurboSmart fcd which is adjustable so maybe keeping some safety margin & checking the afr's etc on a dyno, of maybe better still having a afr gauge installed?
Sandra
m100sandra wrote:BUT: would the TurboSmart FCD work/fit on the Elan, i get confused with the 5V bit etc, reading some of the older posts i see 4.5V mentioned but the TurboSmat info mentions 5V![]()
I just like the idea of keeping a fuel cut which this seems to do?
