Standard injectors max
Postby m100sandra » Mon 17.05.2021, 15:25
Just a short ask, any thoughts what boost/power are the standard injectors good for?
m100sandra
Re: Standard injectors max
Postby HJ2 » Mon 17.05.2021, 18:27
0.96 bar without running leaner then stock (from memory)
200 Hp - ish
But someone will jump in to fill in my blanks soon :-)
Postby m100sandra » Mon 17.05.2021, 20:38
The short story is that.... running a standalone ecu at around 1 bar, all is fine on the dyno, on the road at 6000 rpm it pops and bangs and holds back, i was thinking it could be the standard injectors which are maxed out? the contradiction to the injectors maxing out is.... the dyno operator played around with the cam angle sensor (closing the gap) and this improved things a little.
m100sandra
Postby HJ2 » Mon 17.05.2021, 20:51
Was the base timing set as per manual?
That said: there is also experience here where base timing procedure did not work, but trial and error and lots of trial runs on public road with elanscan delivered the result as expected.
After a check, the base timing was off the chart, but the car ran great!
Probably the nick in the cranc shaft pulley was not correct…
I would start by setting the base timing though!
With a run with elanscan in the current situation will show the duty cycle of the injectors!
Postby m100sandra » Mon 17.05.2021, 22:14
Thanks for the advice, he took it out for a spin tonight and its running OK? weather/air temp related?
m100sandra
Postby Simon_P » Tue 18.05.2021, 13:12
What was the reason for and result of closing the gap please?
There is some background and dyno charts on the Mountain Chips site - See link above.
Also try the Robietherobot.com site for a good discussion on Injectors. (same injector as Impulse RS)
Have you checked the fuel pressure? If the issue is marginal and you could try increasing the fuel pressure.
Return to Upgrades
