Seat Heaters - Fitting
Postby Saltire » Fri 25.03.2022, 16:11
Those who’ve fitted seat heaters to their Elans: how did you do it exactly?
I have the seats stripped down, and a pair of carbon fibre pads to fit to each seat. The backrests are fine, but I have a problem with the bases. The leather seat material is fixed round the edges (which I was expecting) but is also fixed across the middle of the seat by two transverse metal bars embedded in the foam. The underside of the leather has loops sewn in which are fixed to the transverse bar with hog rings.
I wasn’t expecting that :shock:
So, given that I can’t start cutting holes in the heat pad, and I need to fix the leather back to the seat foam somehow, I’m stuck.
Can anybody point me in the direction of a seat pad with holes or gaps in the wiring for the loops and hog rings? Or can you suggest an alternative way of fixing the leather to the heat pad and seat foam?
All ideas welcome please :D
Re: Seat Heaters - Fitting
Postby Simon_P » Fri 25.03.2022, 18:19
From memory you need to undo all of the hog rings and I think that the bar can slide out.
Have you read the write-up?
Having just re-read it I don't remember cutting any wires but I do remember them being hard to get out.
Postby dapinky » Fri 25.03.2022, 19:23
I fitted mine to Honda seats, but the process may work the same.... remove the metal hog rings and after fitting the heating pads, refit the cover using cable ties (avoiding the metal heating elements)???
Postby Saltire » Sat 26.03.2022, 19:51
Thanks both
Return to Upgrades
