Speedo reading 20Km/hr less than actual
Postby frog » Tue 30.05.2006, 18:35
After changing my dials to nice white Lockwood ones - everything seemed OK except that when starting up, the speedo wouldn't move until I was travelling at about 20Km/hr - then would always read 20Km/hr out (checking with my satnav). I've checked that the speedo cable is plugged in and after pulling it out and replacing it a few times, nothing changed. Does anyone have any ideas - I'm sure if I leave it like this, I'll get a whole host of speeding tickets..
frog
Postby Monty » Tue 30.05.2006, 20:14
Make sure the dial is lying flat and that it`s not catching the base of the needle. There not a perfect fit and cause the locating holes don`t line up they end up bowing and touching the needle.
ps u have removed the old dials?
Postby frog » Tue 30.05.2006, 20:52
Yes, the needle is well clear of the dial and seems to move freely when spinning the connection to the speedo cable. And I did remove the old dials first!
Anyhow, I doubt that it catching the dial is likely as it reads a constant 20Km/hr less than it should at all speeds - it is rather puzzling.
I hope I don't have to take the thing apart again! :roll:
frog
Postby Paul.P » Tue 30.05.2006, 21:18
Frog, you didn't remove the needle when changing the dials , did you ?. Also, did you check the speedo was pushed all the way home ?, can't say ive had any problems after the dial change :?
Postby frog » Tue 30.05.2006, 21:32
No - didn't remove the needle at all - and I've pulled out the speedo cable and plugged it in a few times. Just seems wierd. All I really need to do though is move the needle up 20Km/h and I'll be fine. Could I have shifted the needle while installing the dial - and if so, could I just push it back?
frog
Postby frog » Fri 02.06.2006, 11:47
Looks like (somehow) I shifted the needle, so I puuled it off the spindle and reset it. My neighbors must have wondered what I was up to as I was going up and down the road at differing speeds each time trying to calibrate the dial with the GPS. After 3 attempts I got it reasonably close (erring in the cautios - slower side by 1-2Km/h)
frog
Return to Upgrades
