BBR Kit
BBR Kit
Postby Mike Y » Sat 17.03.2007, 15:06
Anyone got the fitting manual for a BBR Kit they can copy?
Regards Mike
Mike Y
Postby Capman » Fri 25.05.2007, 11:56
Did you get one?
I think I may have a copy somewhere.
Capman.
Elan SE 66k miles
Capman
Postby Enright » Fri 25.05.2007, 13:08
No but I can provide a very useful late addendum:
1) Remove kit, place on floor and stamp on it several times.
2) Go to www.elanchips.com and purchase far more sophisticated and reasonably priced alternative.
Happy to be of help! :-D
Postby Mike Y » Fri 25.05.2007, 17:45
No I did not get an instruction manual. Do you have one?
Regards Mike :wink:
Mike Y
Fuel Cut Defender
Postby lotuselan4455 » Tue 29.05.2007, 23:53
Does anyone know how the FCD can be overridden ??
lotuselan4455
Postby Candles » Wed 30.05.2007, 10:47
Yes, take it out. The FCD simply adjusts the signal from the MAP sensor to the ECU, hence the removal of it will restore the output to normal.
If you are wanting to override the fuel cut itself, then visit the ESM Mountain Chips page mentioned above and that will show you a potential way forward. Remember, the fuel cut is there for a reason!
Candles.
Candles
Postby Mike Y » Wed 30.05.2007, 10:47
I have a BBR kit lying in my garage supplied with an Elan I bought a few years ago. As I had a brand new engine fitted I did not think it a good idea to re fit the BBR kit, now I just thought it might be worth a try or someone can buy it off me if they are interested.
Regards Mike
Mike Y
Postby Capman » Tue 03.07.2007, 21:29
Hi Mike,
Just remembered this post. Yes I have a copy of the fitting instructions in PDF. If you PM me your e-mail address I will forward to you.
Craig.
Elan SE 66k miles
Capman
Return to Upgrades
