17" Momo GT2 wheel holy grail
Postby DeeAitch » Wed 06.02.2008, 14:11
nitroman wrote:Gents, I've not researched it toward finitum as you two have, but I've not ever gotten a reason why the ECU receives vehicle speed information.
So ESM could develop a program to calculate acceleration times and BHP :P
I'm 99.9% sure the speedo itself gets it's signal, or is it input :? direct from the cable.
DeeAitch
Postby GeoffSmith » Wed 06.02.2008, 16:08
I suspect it's for increasing the engine speed when the PAS is working hard at low speed - there is a flag recorded in ES logs for "Steering Load Normal".
DeeAitch wrote:I'm 99.9% sure the speedo itself gets it's signal, or is it input :? direct from the cable.
The speedo is purely mechanical.
Postby tweetdriver63 » Wed 06.02.2008, 17:10
geoffsmith wrote: I suspect it's for increasing the engine speed when the PAS is working hard at low speed - there is a flag recorded in ES logs for "Steering Load Normal".
We also know the idle RPM (or tickover, for you RHD types) tends to stay high when the engine isn't up to normal operating temp, and the car is moving. There was some discussion of this on another thread, but no consensus as to why this occurs. Clearly, the signal from the VSS to the ECU is involved in this. (For those not familiar, watch to see if your car goes to an idle of about 1500 RPM or so (when cold) when you push the clutch in and release the accelerator as you approach a stop, then when you get to a complete stop it drops to the normal 950.)
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby tweetdriver63 » Thu 07.02.2008, 20:43
L.G. wrote:Oops my mistake :-D Sorry about that 9 mm is correct. I agree when you drive normally you wouldn't spot the difference, I still won't do it though. :D
As for the speed sensor thing I don't know but my VSS isn't working at the moment and ECU does everything quite well; other than when you're going downhill and engine is in decompression.
Will be more careful next time
L.G.
A 9mm change in ride height is almost exactly the same as the difference between worn tires and new tires. I can't imagine that would be such a big deal. (Pirelli p-zero's have 11/32 tread depth on a new tire=9mm.) Again, I'm not making a recommendation, just an observation.
'91 Elan SE
tweetdriver63
Postby Ekapol » Fri 08.02.2008, 11:02
tweetdriver63 wrote:A 9mm change in ride height is almost exactly the same as the difference between worn tires and new tires. I can't imagine that would be such a big deal.
:smt017 I kinda like my tires when they are new. :-)
Ekapol
Re:
Postby garymb » Thu 28.08.2008, 21:57
lotusgirlmarie wrote:Pic of the way my car used to look with the MOMO GT2's...
Very nayce
Ooooh, that's lovely. (The car looks great too)
garymb
Return to Wheels and Tyres
Users browsing this forum: No registered users and 16 guests
