Sy V wrote:Good poll too!
I've removed the "Who cares!... It's only Gary" option.
Breed wrote:Gary
If your buying Michelins, worth the money by the way, why not do as they recommend. Extract from their web site is below. IF you don't believe what they say why buy their tires in the first place
Whether you have front or rear wheel drive, we recommend that you use newer tyres for the rear set, for extra safety in unforeseen or difficult situations (emergency braking, tight bends etc) particularly on wet surfaces.
Numerous tests have shown that it is easier to control the front wheels than those at the rear.
Front tyres generally wear quicker than those fitted at the rear, particularly on front wheel drive cars, which are currently in the majority.
New tyres fitted in front :
- The behavior of the car will change, because the front / rear balance will be reversed.
The driver, used to a car with less grip at the front, will therefore be taken unawares.
- On a slippery road, the rear will lose traction before the front of the vehicle.
The driver will have no chance of controlling the rear, and will be tempted to accelerate further, which will amplify the spin effect. Only an experienced driver will be able to recover from this dangerous situation...
New tyres fitted at the back :
- The handling of the vehicle will be similar to that known by the driver before the tyre change, because the traction balance will be the same.
- Rear traction will be better, and the driver will be able to control and steer their vehicle without a problem by decelerating and turning the steering wheel in the direction of the bend.
That's why Michelin advises you to reduce the risks you take by fitting new or less worn tyres at the rear of the vehicle for:
- better grip on bends
- extra safety.
Also car mechanics have a few pages on it and this may be of interest as well
"Some tire dealers have been sued for putting the new ones on the front when the customer later had a spinout accident."
Its easy for us to say what is better sometimes. Even bald tires give better grip under some circumstances.
Over to you Ray I am sure you will tell us why Michelin know nothing about tires javascript:emoticon(':wink:').
DeeAitch wrote:Rambo wrote:I only paid a bit more for mine £70 + vat for all the works
Where from Rambo? I need 2 new ones - for the rear of course
dapinky wrote:The next issue, is during the skid itself - as heat builds up between the tyre and the road, bits of rubber on the tyre surface will melt, causing a 'wet patch' between the road and the tyre - this is what leaves the top skid mark - and gives the same effect as aquaplaning.
If the road is TARMAC, then oil will bleed out of the road surface as well due to the heat, further exacerbating the effect - this is why skid marks 'develop' after a skid and often get longer - this is the second-level skid mark.
dapinky wrote:Hang on a minute.................On the point about totally bald tyres...
