oz wheel
oz wheel
Postby D3DSY » Wed 04.07.2007, 21:14
i need an 15" oz wheel for my se can anyone help???? :)
who needs knuckles anyway??
White 1991 se turbo
D3DSY
Postby AndyH » Wed 04.07.2007, 22:03
If you can wait about 4 weeks, yep :D
AndyH
Postby a5gcd » Thu 05.07.2007, 14:37
Where are you located?
I've got one that needs a refurb. Just cosmetic.
Geoff
a5gcd
Postby Enright » Fri 06.07.2007, 12:50
a5gcd wrote:I've got one that needs a refurb.
Same here.
Or to be a bit more precise, I've got one that's HAD a refurb and is cosmetically brilliant, but which has a slight wobble on the rim.
If you've trashed an alloy beyond repair and need something to get you back up and running, then this will be fine (especially if you can find somewhere that will true it up that last little bit).
Postby D3DSY » Fri 06.07.2007, 21:30
i'm in stirling scotland . i could use a wheel with only cosmetic damage but the reson i need one is coz one of my calliper bolts came loose and the other sheared off sending the calliper bouncing around inside the alloy and buckled the mutha hubbered :shock: :shock: :shock:
White 1991 se turbo
D3DSY
Postby D3DSY » Fri 06.07.2007, 21:32
reason. ps always preview your psots :lol:
White 1991 se turbo
D3DSY
Postby AndyH » Mon 09.07.2007, 10:25
D3DSY wrote:i'm in stirling scotland . i could use a wheel with only cosmetic damage but the reson i need one is coz one of my calliper bolts came loose and the other sheared off sending the calliper bouncing around inside the alloy and buckled the mutha hubbered :shock: :shock: :shock:
curiously - the reason I ended up with an extra set of wheels was for the very same reason... and it happened in stirling as well on the A9... oooohhh
AndyH
Postby D3DSY » Thu 12.07.2007, 00:01
MINE BROKE 1 1/2 MILES FROM A9 ON A B ROAD NEAR DOUNE :shock: SPOOKY S&$T
White 1991 se turbo
D3DSY
Postby Enright » Thu 12.07.2007, 00:21
Are you hanging on for Andy's or do you want one?
Postby D3DSY » Sat 14.07.2007, 13:53
cant have no wobble i'll wait for andy's cheers anyway :wink:
White 1991 se turbo
D3DSY
Return to Wheels and Tyres
