DaveB wrote:Hi
I work for BMW....if I have to...![]()
And yes this is the offset...The bolt pattern is the same as an Elan but the centre will need machining to enlarge it by a little...
If you can get me the part number, also stamped on the alloy, I can confirm the size and offset if you wish.
DaveB
DaveB wrote:Hi
DaveB
Nige wrote:When I worked out that BMW mini wheels would fit the Elan and provided a good option for track day wheels I originally wanted the 'minilite' style but the outer end of the spokes at the rim on the inside of the wheel fouled my Hi Spec Calipers (even with 17" rims). I ended up with the 5 spoke 'bullet' style wheels which have plenty of clearance and yes they are a 48mm offset.
texas2201 wrote:Godalming is not far away - is that Coombs?
texas2201 wrote:Sorry DaveB didnt mean to upset you they are the only ones I know in the region and that info is from about 18 years ago LOL
so who do you work for? no PM?
cheers
Martin
texas2201 wrote:
Monty do you have details of your wheels? make model etc
Only used R888's and used to use the same size as Niges on my M3 - hence looking for 17" alloys I was getting them for £103 delivered from Camskill but it looks like the 16's are about £20 dearer in the Kumho range - any experience of these Monty?
cheers
Martin
, so i stuck them on the front when i did a bedford day and the grip was awesome which solved my understeer out but i ended up with snap oversteer and spun a couple off times
Since i was new to trackdays and was struggling on tyre pressures and someone said to use 30 psi cold to stiffen the side walls which IIRC ended up running at 40 psi hot and that pretty much worn the center of the tyre
texas2201 wrote:bought a set of 16" mini wheels with ET48 and a set of Hankook RS2's track day tyres
I drove a couple of rentals with these on and was very impressed with their grip - they are not as good as R888's but at £75 a corner they are considerably cheaper and I can stick with the 16" wheels
