Wheel Centre Cap Removal:
Postby Coupeboy » Wed 26.10.2011, 13:09
Had a quick search but is there an easy (any) way to remove the multiple-tab Lotus wheel centres? I just know the local tyre fitter is going to break them! I'm already trying to reduce the risk of damage by just giving them the wheels. Thanks
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
Re: Wheel Centre Cap Removal:
Postby HJ2 » Wed 26.10.2011, 16:16
Depends if they are S1 or S2!
My guess with your wheels: Remove wheel, and press cap into the wheel.
Postby theelanman » Wed 26.10.2011, 16:28
S2 has caps that can be removed from the outside...ie with the wheel insitu.....however its pretty difficult to do
SE has caps pushed through from behind...ie hub side...so the wheel needs to come off to remove them
Postby dapinky » Wed 26.10.2011, 18:34
Assuming the wheels are as per your thread on tyre sizes, I suspect you have the 15" OZ wheels - as Gareth says, they push out (in?) towards the car, and the easiest way to wreck them is to try and hit them the wrong way!
Once the wheels are off the car, a light top with a rubber mallet will unseat them and they can be lifted out by hand.
Should they get damaged, then they were fairly cheap (a fiver a piece) on the aftersales list, but come under the Esprit section, not the elan!!!! ('coz they also fit the esprit OZ wheels)
Postby Dave Eds » Wed 26.10.2011, 18:46
or just pop them back in with a bead of mastic around them - they ain't gonna go far if they come loose :wink:
Postby HJ2 » Wed 26.10.2011, 18:47
Just like i said before :-D
Postby Coupeboy » Wed 26.10.2011, 18:50
Thanks all. Yes they are standard 15". Didn't occur to me to keep pushing in the direction in which they are fitted, I was trying to devise a way to squeeze all the tangs simultaneously and push it outwards. :oops:
2007 325se Coupe
Coupeboy
Postby chrism » Tue 24.05.2022, 18:28
I still couldn't figure out how to remove these SE wheel centres :( so I had a go myself and thought I'd post some pics...
On the 15" SE wheel they are removed from inside the wheel to outside - so you have to take the wheel off first.
From the inside I soaked the black tangs in release oil and used a plastic trim tool as a lever to ensure they 'moved', then later gently went around with the shaft of a hammer on each pair of tangs - hitting the hammer shaft gently with a second hammer, slightly angled towards the centre, then firmly once in the middle - and out they popped, undamaged :)
To reinstall they go back in the same way (from inside to outside - which originally seemed confusing to me) and are held in place by the black tabs (that you have moved then tapped in pairs) like in the 2nd pic. They don't go back in from the outside 'cos they can't, as shown by the last pic...
Hope this helps another 'newbie' like me who wants to get a front wheel balance...
chrism
Return to Wheels and Tyres
