by dravidham » Sun 04.12.2011, 10:31
hi folks
need to find some steel wheels with a little rubber to keep my m100 off the ground while on the sorn, is there a standared
wheel i could use ? regards graham
Lotus Elan M100 S2 - Norfolk Mustard Yellow
dravidham
- Tinkerer
by Dave Eds » Sun 04.12.2011, 11:17
just pump your tyres up to 40psi
by RayD » Sun 04.12.2011, 11:52
Another idea would be to collect three more spacesaver wheels to go with the one in the boot.
- Forum Member
by dapinky » Sun 04.12.2011, 13:32
I should imagine that anything from a 4-stud vauxhall will do the job - as long as they're big enough to go over any brake upgrades you may have (or even standard brakes).
- LEC Administrator
by dravidham » Mon 05.12.2011, 21:41
thanks for your help,i just thought there was a particular model vauxall that could fit the standard m100 wheel. regards graham.
dravidham
- Tinkerer
Return to Wheels and Tyres
