ELAN M100 S2 WHEELS
ELAN M100 S2 WHEELS
Postby roy666 » Wed 16.01.2013, 13:13
Hi all.. just trying to source a wheel for my S2.. hit a pothole and badly bent inside rim. I know these things are like rocking horse dung.. but any ideas, pointers would be great!
roy666
Re: ELAN M100 S2 WHEELS
Postby HJ2 » Wed 16.01.2013, 16:05
Are you sure it can't be repaired?
Postby roy666 » Wed 16.01.2013, 20:18
well, I have not looked at that yet... but I will phone up a few alloy wheel repair places and find out. How much damage cab be repaired?
roy666
Postby HJ2 » Wed 16.01.2013, 20:51
Sow us a piccie then! :poke: :D
Postby stonefish » Wed 16.01.2013, 20:54
done the same to mine and had to go main dealers to get one
stonefish
Postby Jeemy » Wed 16.01.2013, 21:02
I've had some success using a pin hammer and a block of soft wood to tap alloys back into shape. It comes down to two things afaik - getting it to look right, and getting the tyre to sit right. How it impacts on safety is something I am unaware of.
With my van there was an outward buckle to the cosmetic edge of the rim (as opposed to the bearing edge) which I tapped in quite easily and by the time it got a mild sand and spray it was un-noticeable. When I had the tyre changed after the damage occured, they told me, and I don't know how they knew this (Kw*k-F8T), that the damage was cosmetic only but needed to be pointed out. I returned after my "home repair" to have the tyre reseated and checked and they said it was quite OK, including to bear the increased load of a van.
With my previous Audi I tapped a piece of kerb damage outwards after having the tyre removed by a local firm off the vehicle. I then filled in the edges with alloy putty I think its called, and once hard, sanded smooth and then sprayed and lacquered the wheels. These were kept off the vehicle and sold on with photographic evidence of the repair - basically I managed to cover the cost of 3 wheels when the set would have been useless for sale unless I'd repaired the damaged one. Being clear, they were a set of 5 not 4 - I forget what they call it when the spare is a real wheel instead of a wee black steel thing - so the repaired wheel became the spare.
What I am unaware of and what concerns me, is how likely the alloy would then be to suffer from a stress fracture in the case of impact or an accident. I've been warned that even with wood as a buffer, the whole wheel could crack when you try to hammer it even off the vehicle; and what worries me more is that once there is already a slight buckle, thats then pushed back the other way, how structurally sound the whole composition of the wheel, during driving, is after all that direct impact to one section.
This would be something you'd have to decide case by case for yourself.
I'd say that a slight buckle to the cosmetic edge of the rim would be OK in most cases to repair, but I would be very concerned, not that I've ever seen it or had experience with it, with any kind of stress fractures or cracking being repaired or covered over, and being put back on the road.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby cliff » Thu 17.01.2013, 00:17
Hi Roy,
not sure where you are but a company like this can probably help.
http://www.wheelspecialist.co.uk/
http://www.wheelspecialist.co.uk/index. ... ge-repairs
They just refurbed my Alfa wheels and did a great job.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby roy666 » Thu 17.01.2013, 23:19
Thanks cliff.. I'll give them a go.
roy666
Postby HJ2 » Fri 18.01.2013, 09:14
I had my bent wheels repaired several times (Dutch and Belgian roads... :shock: )
Usually they remove the tire, put the wheel on a lathe, heat it up locally and push it into shape with some sort of bearing on the carriage.
Of course you cannot repeat this endlessly as the material brittles every time, but you can repair quite a big dent! (that's why I asked for a photograph so I can estimate if the repair is possible, based on my own experience (so I am not a repair man myself !)
You'll probably get it sorted at one of the addresses as per above.
Good luck and share the results with us!
Postby roy666 » Fri 18.01.2013, 16:44
just trying to upload an pic.. hope this works
roy666
Postby HJ2 » Fri 18.01.2013, 16:49
If there are no tears or bits missing, , it looks repairable to me!
Postby steve matthews » Fri 18.01.2013, 17:05
Repairable :-D
Steve -w- 2 repaired S-2 wheels
steve matthews
Postby rip » Fri 18.01.2013, 19:28
That's quite a dent. You may find that some places will tell you it can't be done...but some places are better than others.
Postby roy666 » Fri 18.01.2013, 20:40
ok guys, I'm gonna give it a go. Think I'll use Pristine wheels... they just came across better than Wheel Specialists.. and the deal is a little bit better.. I'll let you know how I got on.
roy666
Postby nicowalker1 » Wed 26.06.2013, 21:10
how did you get on?>
nicowalker1
Return to Wheels and Tyres
