by ab2cv » Sun 28.11.2004, 11:52
[quote author=Candles link=board=wheels;num=1101064642;start=0#3 date=11/25/04 at 09:42:21]If it is a wheel bearing, you should be able to tell on smooth tarmac coasting with the clutch depressed, which end of the car it is coming from. Try with the roof down as well. To tell which side, drive as above and corner reasonably sharply. If the rumbling sound goes up in pitch, then you have just made it the outside wheel of your turn. I know this sounds stupid, but it does actually work. Do it loads of times and both ways to make sure. [/quote]<br>This is exactly the technique I was trying to work out which bearing it was. Trouble is, it never got any louder with cornering and even with the roof down it was difficult to tell if it was front or back (also difficult to find 'smooth' tarmac on scottish roads!)<br>When my rear wheel bearings were away, it was obvious the noise was at the rear and this time it seems slightly different so it could be the front. I'm going to check the obvious things first (tyre pressure, wheel bolts, dead squirrels etc), but from the suggestions I'm thinking either front wheel bearing or driveshaft.<br>I don't think it's warped discs, unless only very slight as this problem normally shows itself in lots of other ways like vibrating steering wheel and shuddering on braking, which I don't get (at least not yet)<br><br>#521 - very close - could mean the cars were 'born' on the same day - Lotus twins seperated at birth?
Yellow Esprit GT3
