Hub Retaining Nut (A100R6002F)
Postby donsladek » Mon 14.07.2008, 00:31
The OEM hub retaining nut has the following dimensions:
Threading - M22-1.5
Height -19mm
Outer diameter of integral washer - 42mm
Hex size - 32mm
I've found a Beck-Arnley part which is close to the original. This is part 105-0519, available at Rock Auto for $3.73 US each. Differences from original:
- Outer diameter is 45mm vs 42mm on OEM
- Height is 20mm vs 19mm on OEM
- Threads do not extend to the top - they stop about 5mm from top, and the top area is cut back proud of the threads. This requires additional "peening" to cause interference with the axle shaft keyway.
I've fitted these to my car, and the greater OD still fits within the hub with clearance. They are made in China, however. :roll:
The applications for this part are listed as:
FORD ESCORT (1993 - 1997)
FORD ESCORT GT (1992 - 1996)
FORD ESCORT LX (1992 - 1996)
FORD ESCORT LX-E (1992 - 1993)
FORD PROBE (1993 - 1997)
FORD PROBE GL (1989 - 1992)
FORD PROBE GT (1989 - 1997)
FORD PROBE LX (1989 - 1992)
KIA SEPHIA GS (1994 - 1997)
KIA SEPHIA LS (1994 - 1997)
KIA SEPHIA RS (1994 - 1997)
MAZDA 323 (1990 - 1993)
MAZDA 323 SE (1990 - 1993)
MAZDA 626 (1988 - 1992)
MAZDA 626 DX (1990 - 1997)
MAZDA 626 ES (1993 - 1997)
MAZDA 626 GT (1990 - 1991)
MAZDA 626 LX (1990 - 1997)
MAZDA MX-3 1992
MAZDA MX-3 GS 1992
MAZDA MX-6 (1988 - 1995)
MAZDA MX-6 DX (1991 - 1992)
MAZDA MX-6 GT (1988 - 1992)
MAZDA MX-6 LS (1993 - 1997)
MAZDA MX-6 LX (1991 - 1992)
MAZDA MX-6 RS (1996 - 1997)
MAZDA PROTEGE 1995
MAZDA PROTEGE 4WD (1990 - 1991)
MAZDA PROTEGE DX (1991 - 1997)
MAZDA PROTEGE ES (1995 - 1997)
MAZDA PROTEGE LX (1990 - 1997)
MAZDA PROTEGE SE 1990
It appears a NAPA part # BK B301642 is also equivilent.
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
