Front wheel bearing
Re: Front wheel bearing
Postby Specky » Sat 06.11.2010, 13:06
As most of the links are obsolete, here's a new one
£30 for a pair + £7 P+P (They are chuffing heavy)
http://www.vauxhall-car-parts.co.uk/aca ... 6460N.html
Postby Specky » Fri 26.11.2010, 16:50
Here's another bearing, about £40 a pair.
Each bearing comes with two circlips (and a split pin)
DriveTec DWB436
http://www.camberleyautofactors.com/home/index.php
Postby stonks » Thu 15.09.2011, 11:39
Hi all, this may help...
art Number: CDK436 front wheel bearing
Equivalent: QH QWB436
To Fit Makes: Lotus, Vauxhall
Elan 1.6, 1.6 Turbo 90-95
Astra MKI, MKII 1.6 81-87
Astra MKI, MKII 1.6D, 1.7D 84-91
Astra MKI, MKII 1.8, 1.8i, 2.0i GTE 8v, 16v 83-93
Astra MKIII 1.4, 1.6 Manual 91-93 to ch P#999999
Astra MKIII 1.4, 1.6 Auto 91-93 to ch P5072914
Astra MKIII 1.7D, TD 91-93 From ch P5072915
Astra MKIII Cabrio 1.4, 1.6, 1.8 2.0 Auto 93-
Astra Classic 1.8i 16v 96-
Calibra 2.0 8v 89-95
Calibra 2.0 8v Turbo 89-92
Calibra 2.0 16v 89-97
Calibra 2.0 16v Turbo 4x4 89-95
Carlton MKII Saloon 1.8, 2.0, 2.3 D, TD 87-93 Rear Wheel Bearing
Cavalier MKII 1.6 82-10/88
Cavalier MKII 1.6D 82-88
Cavalier MKII 1.8, 2.0 82-10/88
Cavalier MKIII 1.6, 1.6i Auto 88-94
Cavalier MKIII 1,7 D, TD 88-95
Cavalier MKIII 1.8i 88-95
Cavalier MKIII 2.0i 8v, 16v 88-94
Cavalier MKIII 2.0i 16v 4x4 88-95
Astra Van MKI, MKII 1.6 82-86
Astra Van MKI, MKII 1.6, 1.7D 82-91
Astra Van MKIII 1.7TD 91-93
Astramax 1.6 85-86
Astramax 1.6D 85-91
Astramax 1.7D 85-94
Astramax 1.7TD 91-93
stonks
Postby Camalot » Sat 29.11.2014, 21:49
The Lotus ELAN M100 Front Bearings cross references supplied seem to only be available in UK and Germany. I have some other cross references easily obtainable in the USA below. I went w/ the FAG which are German made. If you want a car sold in USA to have someone search for or just buy BMW (FAG) bearings, the 96-98 BMW Z3 RoadsterL4 - 1.9L 1895cc type M44 - MFI GAS DOHC use the same bearings.
FAG GbmH 542186A
TIMKEN 513113
BCA 513113
BECK/ARNLEY 051-3912
QUINTON H QWB436
ACDelco FW131 (mfg by Timken)
GM 88936180
NATIONAL 513113
The Timken cross reference manual shows the OEM SKF part BAHB 311396B mapping to the #s above. Other sources show the 513113 coming up if they have listing for Lotus Elan M100.
Camalot
Postby Simon_P » Wed 06.03.2024, 00:15
Matt, I think this is what you are looking for!
SKF VKBA736 is I think the kit,but I've always had to reuse the circlips as they are often the wrong size.
Postby FunElan » Wed 06.03.2024, 06:11
Hi Simon! I did go off of this thread. I ended up finding a set of bearings for $11 US each. RockAuto actually lists a whole bunch for the Elan! They fit the ID/OD/Width requirements:
Centric 41249000E
FunElan
Postby Camalot » Fri 08.03.2024, 06:01
Folks,
I actually pulled the old bearings out and looked at the part # on them. Put them back in and ordered the replacements I mentioned in post several years ago.
The bearings were as previously mentioned
https://www.skf.com/my/productinfo/prod ... 311396%20B
But I went w/ the German ones. As I had to replace the SKF at fairly low mileage and don't track the car. I do autocross it, might have caused some stress.
Camalot
