by Freelander » Thu 20.11.2008, 23:42
Does anyone have a source for Kaylock nuts?
Thanks, John
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
by inkitin » Thu 20.11.2008, 23:49
Freelander wrote:Does anyone have a source for Kaylock nuts?
Not easy to find are they?
I'm not certain but I think
these may be them.
Roland
91 SE Calypso Red
inkitin
by Freelander » Mon 24.11.2008, 00:45
Thanks, the K-nut should be the Kaylock - I'll give them a call to check.
Thanks again
Freelander
by inkitin » Mon 24.11.2008, 20:19
Freelander wrote:the K-nut should be the Kaylock - I'll give them a call to check.
John,
Could you post the result of your check back on here please. I and possibly others would like to know.
Roland
91 SE Calypso Red
inkitin
by GeoffSmith » Mon 24.11.2008, 22:29
I'd be interested to know what you're doing with them as well John.
- Kitty Fiddler
by F1 LOTUS » Tue 25.11.2008, 07:18
F1 LOTUS
by inkitin » Fri 09.01.2009, 00:41
inkitin wrote:Freelander wrote:the K-nut should be the Kaylock - I'll give them a call to check.
John,
Roland
Answering my own question. I can now confirm that the K-nuts link I gave, as well as the Trident Racing nuts linked by F1 LOTUS, are in fact Kaylock nuts.
Geoffsmith wrote:I'd be interested to know what you're doing with them as well John.
Well, if John is anything like me, then he is using them for his front suspension. For instance, the four bottom front damper bolts are specified by Lotus parts guide as using Kaylock nuts. There are other Kaylock nuts as well in the front suspension.
Roland
91 SE Calypso Red
inkitin
by Doug » Fri 09.01.2009, 00:46
inkitin wrote:Well, if John is anything like me, then he is using them for his front suspension. For instance, the four bottom front damper bolts are specified by Lotus parts guide as using Kaylock nuts. There are other Kaylock nuts as well in the front suspension.
Roland
agreed, was just playing with those nuts in my Saab suspension installing new bushings and dampers last week . . . = common to auto suspension
- LEC Founder
by inkitin » Fri 09.01.2009, 00:52
Doug wrote:agreed, was just playing with those nuts in my Saab suspension installing new bushings and dampers last week . . . = common to auto suspension
Hi Doug
Do you happen to know why Kaylock nuts are specified, as opposed to other locknuts? Such as Nyloc, which seem to be used everywhere else on the suspension !
Roland
91 SE Calypso Red
inkitin
by nitroman » Fri 09.01.2009, 02:21
Are kaylocks the ones in which the nuts are somewhat 'crushed' in order to put extra pressure on the bolt threaded through them?
nitroman
by GeoffSmith » Fri 09.01.2009, 08:55
- Kitty Fiddler
by bobbrown » Fri 09.01.2009, 09:56
I always thought "K Nuts" were like this
Usually high tensile 10.9 and high temperature used in gas turbines as one example and in motorsport to secure discs to bells but are not cheap.
http://www.brspecialtuning.co.uk/Consum ... m#K%20nuts
Pacific Blue N/A
by inkitin » Fri 09.01.2009, 13:14
Yes Bob, those are what I now know to be Kaylock nuts.
GeoffSmith wrote:
These are Kep Nuts, confused me for a while, as well, when I was looking for the kaylock.
91 SE Calypso Red
inkitin
by RayD » Fri 09.01.2009, 15:34
Hi Roland,
I imagine they did it to try to match the quality of the bolt and nut together.
- Forum Member
by inkitin » Sat 10.01.2009, 10:51
RayD wrote:I imagine they did it to try to match the quality of the bolt and nut together.
Thanks Ray, that makes sense.
91 SE Calypso Red
inkitin
by GeoffSmith » Sat 10.01.2009, 13:01
bobbrown wrote:I always thought "K Nuts" were like this
I thought those were
Jet nuts but I see they're also known as K-nuts! I stand corrected on the
Keps™ nuts but I see they're also known as K-nuts!!
- Kitty Fiddler
by bobbrown » Sat 10.01.2009, 14:39
They are probably known as jet nuts due to link with the aero space industry and I think it was the B52 that they managed to save 600lbs of weight using these, must have been a lot of nuts!
Pacific Blue N/A
by inkitin » Sat 10.01.2009, 16:45
bobbrown wrote:must have been a lot of nuts!
A bit like all of us I suppose !
91 SE Calypso Red
inkitin
by Doug » Sat 10.01.2009, 17:12
- LEC Founder
by nitroman » Sat 10.01.2009, 21:56
Some of us have more weight in our nuts than others, I suppose.
nitroman
