Instruments - what are they from? Any oilthermometer?
Postby Don.Hasi » Fri 29.05.2009, 00:14
Hi,
I´m searching for an oilthermometer cause I have to check the high oiltemps under the flat nose... I prefer the same style of the stock instruments... Do you know whether there exist any oilthermometer?
Thanks in advance for an advise
Kind regards
Don.Hasi
Re: Instruments - what are they from? Any oilthermometer?
Postby bobbrown » Fri 29.05.2009, 08:29
The stock instruments are VDO so this one should be easy enough to pick up but you will need a suitable sensor but it probably will not be an exact match in terms of colour of the dial.
I believe Monty fitted one in the line to or from the oil cooler.
Pacific Blue N/A
Postby Don.Hasi » Fri 29.05.2009, 16:02
Hi Bob,
thanks for the help. Yes we have the same technical base. The dials of the 3 clocks in the middle are slightly different but as the originals, they are in a kind of a quarter-scale with the same two bolts.
All VDO-gauges in the aftermarket i found have the halfscale like you example.
Does there any 1/4-scale exist? And/or, are the original-gauges from a specific vauxhallmodel or sth different too?
Kind regards
Don.Hasi
Postby bobbrown » Fri 29.05.2009, 16:27
I think the basic gauge is the same, it is just rotated 45 degrees with a custom face.
You could get the dial faces changed so they all match see
http://www.metal-monkey.co.uk/acatalog/ ... Turbo.html
and I am sure if you ask them to make up a dial face that reads the same as the one above but is rotated 45 degrees it should not be a problem
so with a full set of matched dial faces + the oil temp one in a colour etc of your choice.
I have just spoken to them and it can be done as I need a analogue clock face and no boost gauge.
Pacific Blue N/A
