by ashm » Mon 01.03.2010, 17:13
Hi all,
apologies if this is already mentioned somewhere, but I found this list on a part cross-reference for our ignition coil
here:
09/89 to 11/95 LOTUS - ELAN 1.6 i 16V Turbo Petrol Engine (4XE1-T)
08/90 to 09/92 OPEL - OMEGA A (16 , 17 , 19 ) 3.6 24V Lotus Petrol Engine (C36GET)
08/90 to 09/92 VAUXHALL - CARLTON A (16 , 17 , 19 ) 3.6 24V Lotus Petrol Engine (C36GET)
08/91 to 07/98 ISUZU - TROOPER (UB) 3.2 Petrol Engine
Anybody able to confirm?
Adam
ashm
by Alan_C » Wed 03.03.2010, 00:33
I hope I haven't buggered mine, the car used to have a bit of a full throttle/boost misfire which cured itself (I suspected the coils then), but the other day while refilling the coolant I had a major spillage and soaked the coils in 1 1/2 litres of coolant, the engine was running at the time, the tickover went horrible with the sound of rapid and erratic crackles as the sparks jumped to ground around the soaking wet coils. Left them to dry out, hopefully be OK, else I'll need a new set too.........
Alan_C
by tigerdog » Tue 17.05.2011, 21:58
For our North American friends, in a pinch you should be able to pick up a coil at your local NAPA Auto Parts store:
http://www.napaonline.com/Catalog/Catal ... 36+2036004
