by Davemac » Sun 07.04.2019, 20:40
We are looking for wheel arch lines for our elan which we are restoring I think I am right in thinking the part numbers are LH C100B0591F / RH C100B0592F. Or is there anyone who can manufacture or repair a pair at a reasonable cost. Thanks
Davemac
- Welcome to LEC - please introduce yourself
by kevinrooney » Thu 12.09.2019, 14:43
you can try a plastic welding repair with a soldering Iron - have a look on u tube if you cant get the parts needed
pick up some wheel arch liners from the scrap yard for filling in the missing bits around the leading edge
kevinrooney
by uk08462 » Thu 24.10.2024, 14:29
I have a damaged wheel arch liner too. Any suggestions as to what material can be used to repair it?
S2 #048 BRG
uk08462
by Jamie N » Thu 24.10.2024, 17:31
As Kev says above, heat welding with an old soldering iron works well, used with some cut up strips from an old liner from a srappy, or indeed any similar type of thin
plastic, wont be the prettiest repair but It'll do whats required, but make sure it's done outside, the smell is also not very pretty, in fact seriously ugly for lungs!.
Jamie N
- Seal God
