by dapinky » Sun 22.01.2023, 13:27
I have to admit, I haven't even looked at the suspension on mine yet - I simply formed a shopping list to replace all the bits I like to change as a matter of course (all bushes, all nuts/bolts/washers for stainless ones, top balljoints, etc) I like to change the shocks before I use the car 'properly' but for the time being, the old ones will hold the car off the ground. Springs just get changed as they are (comparatively) cheap........
..... I have never heard about the actual 'spring rate' remaining the same, even if the spring is shorter - but if that is true, then just swapping shocks to 'adjustable platform' ones will get it back to OE spec.
At the moment, the only info I have is from an old MOT advisory which states "Coil spring corroded X4".... that was in March 2016, the car has been driven 788 miles since then, and then left sitting on a driveway - so i don't suspect that they have improved much since the last MOT!!!!
That said, they may just require a strip/repaint - won't know until I get to that bit, so there is no actual rush.
My current state of play is that the car has been sitting in the garage for 4 days, with the de-humidifier running, drivers seat is out, passenger to be done today, carpets appear quite dry, and jacking points seem solid from outside...... so I will be whipping the carpets out and stripping the bodyshell enough to assess and then either repair or treat any rust on the outriggers/sills before replacing the underfelt with closed-cell foam. Then it's on to the engine, get the waterpump & cambelt replaced so I can see about turning it over. Once I get it running, it'll be on to the suspension (by then the bushes and top balljoints should have arrived, so I can replace it all. I am fortunate enough to have a pair of spare rafts, so I have cleaned them up, removed the old bushes, and can rebuild them with new top wishbones before having to take anything off the car - then it is a (slightly quicker) case of taking one off, putting one on and not being delayed with too much cleaning and painting the old parts (well, only the bottom TCA/triangular link)....... sounds easy - we'll see how long it actually takes by the time I've found other bits to do along the way - I usually manage to do a lot more, and that involves searching for odd parts and refurbishing stuff that never gets seen.
