O2 sensor UK part no. and excellent test info guide website.
Postby Andrew_Ennis » Wed 03.08.2005, 12:43
Does any one know of a replacement part for the O2 sensor. The part nos. on the Repairs guide are not available in the UK or the part numbers for the UK are different. I went through the parts book at the Lucas UK part supplier with no luck.
Also i have found an excellent write up on O2 sensors and how to test them. Wonder if Alan could code in a diagnostic program in to Elanscan so you could test if the sensor is working correctly.
http://www.picotech.com/auto/lambda_sensor.html
Andrew_Ennis
Postby ESM » Thu 04.08.2005, 13:17
I got one here (look at parts for the '91 Isuzu Impulse RS). I got the KEM (its identical to the original) it cost $69 + $28.75 postage and came in a couple of days. I can't remember if I got hit for duty as well.
The Bosch universal 3 wire sensor is ok as well you'll just have to re-use the old plug.
ESM
