CAS bearing
CAS bearing
Postby Monty » Sat 16.12.2006, 17:41
I`ve quote this here as i`m sure it will be useful to us oneday and the details are from LUCA from Italy. :smt023
lotuselancentral.com/forum/viewtopic.php?t=8633
*LUCA* wrote:The the manufactures part number of the new bearing is 6000-2RSH for the SKF model. The price in Italy is 3,50 €.
There are then three O-rings:
1°) Located behind the CAS, on the shaft that connects to the camshaft.
2°) Located inside the CAS body, around the bearing.
3°) (Only for the oil leaks!) Located behind a plastic bung adjacent to the CAS.
There is, besides, an "oil seal" with this dimensions "10.22.7" (dimensions are in millimeters). In my CAS this "oil-seal" was very broken as visible in the picture!!
So...I can say: 6,50 Euros VS the CAS noise and the oil leaks!!!!
