Bottom ball joint
Bottom ball joint
Postby GeoffSmith » Wed 30.05.2007, 12:43
BMW E30 1984-1991 - see here.
Postby Jamie N » Wed 30.05.2007, 16:05
Here is the part number,its a QH item......
QSJ998S
or equivalent...
MBJ 998.
And the good news is its only £6.34 :-D ,just a tad lower than the £67 one from SJ. :evil: :D
This is a direct replacement with no mods needed,mine is in. :wink:
Jamie N
Seal God
Ball Joint.
Postby ZM » Fri 01.06.2007, 19:12
Does that equal to this BMW Part# 31 12 1 126 254
ZM
Re: Ball Joint.
Postby GeoffSmith » Fri 01.06.2007, 19:26
It appears to be but £20.46 + VAT + delivery or have you found a cheaper source?
Bottom Ball Joint
Postby ZM » Fri 01.06.2007, 19:38
ZM
Re: Bottom ball joint
Postby bobbrown » Thu 07.01.2010, 12:51
Having found some issues with the BMW part and doing some research I have found that the Elise ball joint is a better fit see here
Pacific Blue N/A
Postby londoner » Fri 08.01.2010, 14:02
bobbrown wrote:Having found some issues with the BMW part and doing some research I have found that the Elise ball joint is a better fit see here
Hi Bob,
is it a perfect fit?
londoner
Postby bobbrown » Fri 08.01.2010, 14:36
It is not perfect but very very close, the critical dimensions, taper angle and fit are the same, the fit in the arm is same, there are some dimensional differences but these are limited to mainly not critical dimensions that do not effect the fit.
Pacific Blue N/A
