Drivetrain problems
by Silver Shadow » Wed 18.06.2008, 14:43
I need to change one of my CV boots. It is the left inner one. Can anyone tell me a part number for this please? Is there any opel (Vauxhall) equivalent?
Silver Shadow
by BFG in the BRG » Fri 20.06.2008, 09:56
Hi, i've never had to do this yet but....if you follow this link which is part of the LEC website - it gives you a cross reference for parts
http://www.gglotus.org/ggpart/m100xref.htm
being as the CV joint joins onto the engine, and the engine is an Isuzu - it is quite possible that there is no GM part - hence the cross reference refers you to the Isuzu Impulse.
A good place to go to is
http://www.rockauto.com they're based in America and a lot of people use them as have I, - delivery is pretty fast and with the Euro:Dollar exchange rate - the parts are reasonable - if your Elan is an SE Turbo - then you need to ensure you are looking at the Isuzu Impulse RS with the Turbo Engine
http://www.rockauto.com/catalog/x,carco ... Drivetrain
You can also get split boots which will save you having to split the CV joint - in the repairs section of LEC there is a section on it.
Hope this helps
Alas soon to be Elan-less
BFG in the BRG
by BFG in the BRG » Fri 20.06.2008, 09:58
sorry - the parts interchange link is Golden Gate Lotus Club - not part of the LEC Website
BFG in the BRG
