by muley » Wed 24.11.2010, 12:55
racerstev wrote:Very nice write up!! Can someone tell me the differance between the S1-S2-Isuzu and AB cables? I'm a little confused!
Steve Lockett
'S1' or more correctly NA/SE - plastic ends on cable outers with adjustment on plastic outer at gearbox end
S2 plastic end on gearstick end outer, but metal end with screw adjustment on gearbox end
AB cables - metal ends at both ends of the outer with screw adjustment on gearbox end
3 different brackets required at gearbox end to suit cables.
HTH
by mti88m3 » Thu 30.12.2010, 17:43
The fore/aft movement is great now after some filing, but shift lever doesn't self center at all. Does anyone have experience with this?
mti88m3
by steve matthews » Thu 30.12.2010, 18:19
Indiana, Self center may be the large cable end at trans.
Make sure it also is not super tight. Large washers should turn easily. Cotter pin
may be to tight.------smaller spec. washer.
1. remove large end at trans. with the large washers.
2. center gear shift in cabin (vertical).
3. check relationship to pin position.
4. adjust cable length to accommodate pin.
Hope this helps. It seems to be the logic I followed.
Steve -w- AB cables and short shift just adjusted to inner most
position. Shifter a little stiffer but has less travel than center position or outer
slot.
steve matthews
by muley » Thu 30.12.2010, 20:48
I have found my side to side shift movement to be stiff.. Marie inverted one of the pins and I'll try that because the cable doesn't appear to line up very well at present.
by Specky » Thu 30.12.2010, 21:20
I spent ages on mine and it now self centres, but it's stiff.
When the bracket on the gearbox is mounted, it's causes the rigid parts of the cables to be outta of line with the selector.
by dunnlor » Tue 11.01.2011, 23:39
If the shifter doesn't self center, is this placing a constant load on internal transmission parts?
Will parts like the shift forks or synchronizers wear prematurely?
dunnlor
dunnlor
by steve matthews » Wed 12.01.2011, 01:20
dunnlor wrote:If the shifter doesn't self center, is this placing a constant load on internal transmission parts?
I don't think so, however not having it center would bother me.
How far from Richmond and the Knox Boys.
Steve
steve matthews
by dunnlor » Wed 12.01.2011, 01:44
I'm up in northern, VA, about an 1 1/2 hour away.
Another car of ours kept jumping out of 3rd gear on deceleration. The transmission shop said a common cause is due to driving with a hand on the shifter and putting constant wear on the shift forks.
dunnlor
by bobbrown » Mon 17.01.2011, 14:53
Specky wrote:I spent ages on mine and it now self centres, but it's stiff.
On the original cables the gearbox selector end (not the cross gate) has a rubber bush fitted and this will allow some misalignment much the same as the other end on the gear lever which has a ball joint fitted.
The AB cables have a bush fitted which will not allow for misalignment and I think that is the area that causes the gear selector to be stiff plus it puts unnecessary loads on the cable ends.
This end must allow for the fact the assembly moves in and out as the cross gate cable moves the selector shaft in and out which the AB cables do not allow for.
The cables themselves should allow 8 degrees of misalignment.
Pacific Blue N/A
by dermotbell » Sat 09.04.2011, 17:00
Are you suggesting that despite the more robust design that the AB cables are not quite designed properly to allow the correct movement of the gear lever?
I only ask as I am looking into buying a set as my crossgate cable is knackered.
Dermot
Dermot Bell
dermotbell
by bobbrown » Sat 09.04.2011, 17:53
Dermot
In answer to your question Yes!
you have email
Watch this space another option is in the pipeline using all stainless steel cables
Pacific Blue N/A
by HJ2 » Sat 09.04.2011, 22:04
oohps.. i feel a another groupbuy comin...
by Steve A » Sat 09.04.2011, 22:41
Gimmie Gimmie
I want some
1.Steve A
2.
3.
4.
5.
6.
7.
8.
9.
10.
