Gear shift cable
Gear shift cable
Postby blacksquirrel » Sun 22.07.2007, 14:02
Hello,
One of my gear shift cables has broken and I was wondering where the best place to get a replacement was?
I've done a bit of googleing but so far haven't come up with much.
Any suggestions would be gratefully received.
Many thanks,
Justyn
blacksquirrel
Postby Dico » Sun 22.07.2007, 14:27
I've got one, but they are both different.
If you look at the gearbox end one has a smaller 'hoop' than the other, this is the one I have (well I have 2 actualy).
£30 including postage if this is the one you need. Sods law says it won't be :lol:
Theyre around £170 otherwise :shock:
Yours is an SE isn't it?
Postby al » Sun 22.07.2007, 15:44
I've got a spare of the other one I think (forward/backwards IIRC), which you can have for free if you don't mind coming to pick it up (I'm in London too).
a.
al
LEC Bit Basher
Postby Dico » Sun 22.07.2007, 16:47
Thats a better deal than mine. Lets hope it yours he needs :lol:
Postby blacksquirrel » Sun 22.07.2007, 17:11
Thanks guys.
I'll have a look and see which one it is that's broken when I'm back home on tues and let you know.
Thanks for all your help.
Justyn
blacksquirrel
Postby DeeAitch » Mon 23.07.2007, 08:03
The one with the small 'hoop' is the crossgate cable, if that helps
DeeAitch
Postby al » Mon 23.07.2007, 11:20
Dico wrote:Thats a better deal than mine. Lets hope it yours he needs :lol:
heh, it's just sitting in my house taking up space, couldn't throw it out 'cos I just knew someone on here was going to need a quick spare sooner or later :)
al
LEC Bit Basher
Postby blacksquirrel » Fri 03.08.2007, 16:40
I've had a look now and it's the cross shaft (forwards/backwards) cable that has gone.
Al - I've sent you a PM.
Thanks again for all of your help.
blacksquirrel
