Doug wrote:well on the picture below, the bottom cable is not attached to the bracket with the clip, while the top cable is -- is this your problem? or was it temporarily disconnected to mess about in there?
Ghost wrote:The rubber bush from the gearbox end of your fore/aft cable looks a bit 'chewed' up from your photo!
If you need to check the plastic bush at the gear stick end, you will have to disconnect both of the cables from the gearbox selector and disconnect the cables from the securing bracket. This will then give you enough cable length to remove the gear stick and check the bushing there.
By the time you have done the above, you are well on your way to changing the shift cables!!!!!!!!!!!!!!!
Steve
