CV Boot / Gaiter are these vauxhall Astra type ?
Postby lotuselan4455 » Fri 21.09.2007, 11:14
can anyone please advise me as i'm told the outer CV boots are off early vauxhall astra gte ? does anyone know this and part number ?
lotuselan4455
Postby Oliver » Fri 21.09.2007, 12:11
Hi there,
I`m not sure about the Vauxhall fitment, but you could do what i did.
Go into your nearest Renault dealer and order part number : 8671002726
It`s a complete gaiter kit (boot, grease, clips), and it fits the Elan outer joint perfectly. I`ve had one fitted for six months now and it`s still perfect. Oh, and they`re only £7.72+vat each.
They also suppy a tool in two parts (8671002728 + 8671002727), that allows you to fit the gaiter without removing the joint. An amazing bit of kit.
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby TheBard » Fri 21.09.2007, 20:22
Copied from my post on Parts Cross Ref...
Outer CV Joint Boot, confirmed fit (as it is on my car now) inner connection is not as snug as outer, but a good full seal can be attained with the clips provided.
Manufacturer: Shaftec Automotive Components
Address: Unit 2, 4-5 Cato Street, Nechells, Birmingham, B7 4TS
Telephone: 0121 333 3555
Part #: BK57SB
Description: Constant Velocity Boot kit (Including clips and grease)
Referenced applications: Vauxhall Cavalier, Audi
Note this is the manufacturer, not a sales company, they do not accept telephone orders, do not take credit card, etc...
However, if you phone up, have a bit of a chat, and ask them if you can drive over and pick it up "for cash" then the kit will cost you about two pounds.
According to the box of a part from Lotus these are the original parts manufacturers and this is the same part as used then. Hope that helps,
Ian
TheBard
