Gearbox oil
Gearbox oil
Postby The Ref » Thu 10.01.2008, 18:43
Help how do you top up the gearbox oil ? also what is the right oil to use ?
There are 3 types of people in the world. Those that can add up and those that can't
The Ref
Location: The "pools" HUFC must win a game some day soon
Postby clemo » Thu 10.01.2008, 19:07
if i remember rightly the easiest way is to remove the speedo cable as it mates to the top of the gearbox . on the top there is a little finger( held down by a nut) that holds it down. remove that , pop the cable/gearing out top . top up with long tube and a funnel !.
(mtx i think . )gearbox oil from redline racing is what i used...
best of luck.
clemo
clemo
Postby The Ref » Thu 10.01.2008, 20:34
Thanks Clemo once again this is the best site on the web by far.
Billy
The Ref
Postby dermotbell » Thu 10.01.2008, 22:52
The wikilec on this is not very big but gives an idea of the problems, similar to what Clemo said.
Dermot Bell
dermotbell
Postby The Ref » Thu 10.01.2008, 23:20
Thanks i will give it a go in the morning.
billy
The Ref
Postby DeeAitch » Thu 10.01.2008, 23:54
Some info here as well :wink:
DeeAitch
Postby GeoffSmith » Fri 11.01.2008, 00:27
DeeAitch wrote:Some info here as well :wink:
Well remembered Dave. I've put the link into the Wiki so it's all together.
Postby DeeAitch » Fri 11.01.2008, 22:06
One day I'll get round to checking if the levels are the same at both points :P
DeeAitch
