rip wrote:Sounds very like mine. I need to select reverse before 1st. When I engage the clutch this happens with a lurch forward as something internal appears to move. I can then find my way through the gears up to 5th (but it is a little crunchy).
After removing the (RHD) near side wheel, I could remove the gearbox end cover:
You can see the 2 geartrains. I believe the gear wheel on the right is 5th. Apart from the gears moving against each other, engaging 5th is the only time you see movement from this end.
The nuts Specky is talking about are the big ones (32mm I believe) on the end of each geartrain. The service manual gives a torque of 127NM for the 5th gear one, but I found no mention for the front one. It is the same size & for the same purpose, so I assumed it would need the same torque.
The nut on 5th gear was tight, but the other one was REALLY loose & took several complete turns to tighten.
Made no difference though. I am dropping the car off at GST's on Saturday to have this looked at.
Monty wrote:I wouldn`t mind checking my Nutz![]()
Specky wrote:
Now you're Torque-ing....
I know a certain lady who could tighten your nutz if that'd be any help...
Specky wrote:
When I took the cover off my other gearbox about half a cupful came out, but I don't know how much was in there to start with...
RayD wrote:Out of interest Rip, could you try to find out what’s stopping the various parts sliding back into position when the nut is re-tightened?
Thanks Ray
Users browsing this forum: No registered users and 14 guests
