Enright wrote:(I'd suggest updating your profile with your street!)
DeeAitch wrote:Similar noise on mine turned out to be a wheel bearing
DeeAitch wrote:Turned out to be one or two of the ball bearings shearing in half!
GeoffSmith wrote: Looked like three of my balls were split in half.
Adam wrote:Yes thats right Neil. Went back to the Elan as I just didn't trust that K-series engine in the Elise!
Adam wrote:I think I will change the bearing first as I think that it is the cause (and would make senses as the other side had to be replaced about 9 months ago - albeit for play rather than being noisy).
Adam wrote:If still okay Neil I would like to take up your offer to borrow the hub carrier whilst I get the old one replaced?
Adam wrote:Do you know if the drive shaft simply come out of the hub carrier with minimal effort (once the hub nut is of course removed)?
but then I saw that you were just talking about the driveshaft sliding out of the hub carrier. In which case the answer is yes, it's not really a problem. You're best off starting by removing the wheel, un-peining the nut, putting the wheel back on, lowering the car and chocking the wheel, then using a 32mm socket with a big long extension on it.
Adam wrote:I soon realised where the problem was when I removed the wheel nuts using my fingers! Not one of them was even finger tight!
