by kmckmc » Wed 18.03.2009, 06:47
I am about to replace Drive shaft and Input shaft's oil seals.
Do you know Isuzu's part numbers for those?
http://www.rockauto.com should carry them, right? I checked at rockauto.com but I cannot fine them.
Thanks.
Elan M100 S2
kmckmc
by nitroman » Wed 18.03.2009, 08:45
It's listed as "Crankshaft Seal", under "Engine."
FEL-PRO Part # TCS45853 {Crankshaft Front Seal Set}
DOHC Turbo engine; Crankshaft Front Seal Set
$6.68 $0.00 $6.68
FEL-PRO Part # BS40524 {Rear Main Seal Set}
DOHC Turbo engine; Rear Main Seal Set; Rubber; One-piece; Improved design
$14.61 $0.00 $14.61
TIMKEN Part # 228700
Rear
$15.06 $0.00 $15.06
TIMKEN Part # KWK99128
Kwik Sleeve, Optional Repair; Front
$18.20 $0.00 $18.20
nitroman
